Old 03-21-2010, 12:12 AM   #21
mrshelley
My Ride: 2004 330i
I run Total Quartz Racing 10W50. I seem to run all of that oddball stuff nobody else runs.
Old 03-21-2010, 01:10 AM   #22
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
Originally Posted by Tech@EuroDyne View Post
Why not run the BMW recommended oil and just change your oil more frequently? That's what I do with my E36 M3 Track car.
-Geoff@Eurodyne
Because I'm not doing an extended drain interval anyways. The oil will get changed every 2000-3000 miles because much of it will be on track.
Originally Posted by hamadyr View Post
TU stands for Technical Update. Engines were installed in vehicles headed for the Northeast. Change is in emissions package revised to reduce emissions and qualify as ULEV.
Wasn't that the M56?
I'm even more confused because even Bimmerworld doesn't have a normal M54B30 listed... they only show the M54TUB30
SpeedDemon is offline   Reply With Quote
Old 03-21-2010, 04:29 AM   #23
vaio76109
My Ride: Race Cars
Originally Posted by gte869h View Post
I don't know why anyone wouldn't put fresh oil in and after a track day.
Because that adds up very quickly?
vaio76109 is offline   Reply With Quote
Old 07-24-2010, 12:30 AM   #24
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
So the consensus is 5W-40?
Is that also a recommended grade and weight by BMW. I doubt it matters. I have 2 more HPDE events as well as a few autox thrown in between. I'll likely change my oil after the summer season is over.
phamine is offline   Reply With Quote
Old 07-24-2010, 06:58 PM   #25
AL330CI
My Ride: 330Ci
The relatively new Pennzoil Ultra Euro 5W-40 makes some interesting claims. I would give this a try if I didn't stocked up on the BMW oil already. I've got three change worth before I can give the Pennzoil a try.
If anyone is interested in pursuing this further.
Here's the Pennzoil datasheet: http://www.pennzoil.com/documents/PE...ropean5W40.pdf
Q&A on BITOG: http://www.bobistheoilguy.com/cms/in...d=72&Itemid=80
AL330CI is offline   Reply With Quote
Old 07-27-2010, 11:45 PM   #26
JerryK
My Ride: E46 M3, 03 Cobra
Originally Posted by JamesC View Post
http://store.bimmerworld.com/red-lin...-oil-p298.aspx
SpeedDemon asked me to chime in. First, Red Line being focused on being thin and producing power is a little off. Viscosity is measured and what you are buying is exactly on the label. We (BimmerWorld) often choose to go with a lower viscosity on our racecars with Red Line and we can get away with it because it does have better lubricating properties than many of the other oils in the market. Additionally, the ZDDP package prevents wear, and it has excellent anti-foam and compressibility characteristics that work well with the dual vanos engines.
For most cars, we recommend a slightly higher weight for track use. In that environment, the temps are higher and especially on a hydraulic lifter engine, you usually need the extra viscosity to keep the lifters pumped up. For the M54 on our chart, it is a 5W40. In our racecars, we have been using mostly a straight 40WT in both the M54 and N52 which is similar but requires that we warm the engine up.
I just bought 40wt from you guys for an upcoming track day next Saturday, should be around 98... straight 40wt only makes sense. Warming it up shouldn't be an issue!
JerryK is offline   Reply With Quote
