Sponsored by The Tire Rack
Old 03-16-2010, 04:22 PM   #1
Mikepadin
My Ride: Jet Black ///M3
I Need Tires for my LM Reps..Idea's??
Okay so i just Bought Raderwerks M0-2's
19x8.5 F / 19x9.5 R
5x112
ET35 F / ET40 R
25lbs
See Attached PIC.
Im looking a good Summer Tire , I Live in NYC so i cant get a super low profile (pot holes are a B***h).. I own a 2004 330ci Coupe Performance Package and im running stock suspension i want a tire with a nice tread pattern and something that isnt going to rub all over..
So fellow Fanatics can you guide me in the rite direction of Size,Brand,Compo etc. it would be a great help
Mikepadin is offline   Reply With Quote
Old 03-16-2010, 04:23 PM   #2
jvr826
My Ride: '05 330ci 6MT
19x8.5 F / 19x9.5 R
5x112
ET35 F / ET40 R
25lbs
If the hole pattern is what you say it is, these wheels will not fit your car. The hole pattern is 5x120 on BMWs.
Tire size, well, depends on the offsets, which are on the low end of the scale for our cars. I have the same car as you and I run 255/35/18 on all four corners with +42mm offset 18x8.5 wheels. I have minor rubbing in the rear with this setup, tho I'm lowered, I also have more negative rear camber than a stock sprung ZHP.
I think those 9.5 wide rears with an ET40 are going to limit your choices in tire width. Normally you'd run a 265/30/19 on that wheel I'd guess, but I think it's going to rub based on my experience. You can probably run a 235 on the front with no problems though.
Jeff
jvr826 is offline   Reply With Quote
Old 03-16-2010, 04:34 PM   #3
Mikepadin
Your rite, I did order a 5x120...
