Old 03-16-2010, 08:21 PM   #1
HellRaiser1
My Ride: 2004 M3
Suspension Overhaul Checklist; READY and IMMINENT! Opinions welcome
Ok. So I've been shopping for suspension parts for my e46 w/ 200K+ miles. My poor suspension is shot and in serious need of an overhaul.
Here's my list so far, feel free to mention anything im leaving out, or that i should exclude:
-2 front control arms (meyle hd) + bushings
-new tie rod assembly for right/left
-Sport-Susp OEM front sway bar + endlinks
-Sport Susp OEM front shocks + springs (noticeable or subtle drop on these?)
-Strut tower brace (why not)
-ALL FOUR SUBFRAME MOUNTS
-Rear Differential Mount (NOT all three, but the rear main one, replacing w/ meyle HD)
-RTABS meyle HD .....not replacing all 6, but just the main one on each arm
-Front Shock Mount
-Rear Shock Mount
-Sport Susp OEM Rear Shocks
-Sport Susp OEM Rear Springs
-Sport Susp sway bar w/ rear endlinks
-Steering coupling ....and lube the crap out of that one steering bearing that causes squeaking noises.
QUESTIONS and OPINIONS NEEDED-
- Is it ok if I ONLY replace main RTAB instead of all 3 on each arm?
- Is it ok if I ONLY replace the main rear diff mount and not all 3?
- How do I politely explain to my mech that all these bushings are going to require a special tool, and that if he doesn't use this tool it's going to be a major PIA, and the only reason im mentioning this is so he doesn't rape me and my wallet w/ no lube.
THANKS!!!
HellRaiser1 is offline   Reply With Quote
Old 03-17-2010, 04:54 AM   #2
HellRaiser1
My Ride: 2004 M3
ttt
Old 03-17-2010, 06:00 AM   #3
EDawg
My Ride: :/
those bushings don't necessarily need special tools. as long as the mechanic can remove the old bushings and reinstall new ones, that's all that matters. heck, i installed my RTABS using miscellaneous plumbing parts from home depot.
also, why not go with an aftermarket suspension kit instead of OEM sport? if you insist on sticking with OEM, at least get the ZHP shocks/struts, springs, and sways.
EDawg is offline   Reply With Quote
Old 03-17-2010, 06:18 AM   #4
hvirani
My Ride: e46 320i
+1
Originally Posted by edawg View Post
those bushings don't necessarily need special tools. As long as the mechanic can remove the old bushings and reinstall new ones, that's all that matters. Heck, i installed my rtabs using miscellaneous plumbing parts from home depot.
Also, why not go with an aftermarket suspension kit instead of oem sport? If you insist on sticking with oem, at least get the zhp shocks/struts, springs, and sways.
hvirani is offline   Reply With Quote
Old 03-17-2010, 08:35 AM   #5
HellRaiser1
My Ride: 2004 M3
The reason I don't go for aftermarket or ZHP is because I'd like to have decent ride quality over stiff shocks/struts and wouldn't like to be lowered too much since I live in a big city riddled with potholes and steep driveways and ramps.
Old 03-17-2010, 08:44 AM   #6
jbfrancis3
Formerly Snox400
My Ride: 1999 323i
THANKS!!!
- I just replaced all three bushings on the trailing arm this weekend. The upper bushing is a balljoint, and with 92,XXX miles on my 323i, this was very loose and had lots of play. I would recommend replacing.
- I found that I only needed to replace the rear diff mount, and not the two front. But of course since I had already purchased them, I did replaced them anyway
- Ask him to show you what equipment he has, and based on what you've seen on the forum, you can judge whether he will have success or not. In the end, its your car, tell him what you want done and how you want it done. If I have to bring my car into a shop, I always bring a list of specific tasks.
jbfrancis3
jbfrancis3 is online now   Reply With Quote
Old 03-17-2010, 03:57 PM   #7
HellRaiser1
My Ride: 2004 M3
Cool thanks. I will replace all 6 RTAB Bushings. Autohauz is usually my parts place.
Old 04-28-2010, 09:18 AM   #8
HellRaiser1
My Ride: 2004 M3
PICKING UP MY CAR NOW!!!
2 THINGS:
A) Afraid of what the bill will be. Initially quoted me for around $450-$600
B) Can't wait to see how she rides now!!! Def will need an alignment though.
Old 04-28-2010, 09:28 AM   #9
dawjr
My Ride: 04'325ci convertable
I'm needing to have suspension work done this summer. I have a 04 325 ci vert. Where can I go to get info on the different options out there?
dawjr is offline   Reply With Quote
Old 04-28-2010, 01:27 PM   #10
HellRaiser1
My Ride: 2004 M3
I went to go check up on my car at my Indy shop.
The subframe is out, and all that's left is replacing subframe mounts as well as the RTABS and thats it. (It's going in for subframe inspection and airbag replacement at dealership next week....and subframe looks ok suprisingly!!)
My indy mech was *****ing about how much work I gave him and how theyve been working on my car all day yesterday and today.
IM AFRAID OF THE BILL!!!!
I'm predicting $1000
Old 04-29-2010, 09:21 AM   #11
dawjr
wow...What do you have for a car?
Old 04-29-2010, 01:59 PM   #12
HellRaiser1
My Ride: 2004 M3
00 sedan with 200K + miles.
Getting an alignment right now then all ready. Predicting the labor tag to be about 1K, which still wouldn't be too bad, it'll hurt but better than what most places will charge
Old 04-29-2010, 03:41 PM   #13
SweTurbo
Big Pimpin'
My Ride: 323i -98
1k is pretty hight , but still decent due to all the things you need done
Only thing you missed that i would recommend anyone dropping the subframe is ..... TMS reinforcements for the mounts ^^
Old 04-29-2010, 03:50 PM   #14
BMWstudent
My Ride: hates potholes
Thats a huge list dude! You're going to love it so much more now.
I got my car in September and the first thing I thought was "wow, this car rides like garbage. My e30 was so much better" but then I did the control arms, CABs, tie rods, put in m3 sway bars, koni yellows, ERS of 450# and 650#, and a few other small things and the car really came to life.
It made me fall in love with the car by the time I was done.
BMWstudent is offline   Reply With Quote
