Need help pinpointing vibration on a 2000 323i auto steptronic - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 03-16-2010, 09:49 PM   #1
Pantera7000
My Ride: 2000 323i
I have a 2000 323i steptronic transmission, am33. 109689miles
I have a intermittent vibration that feels like it's coming from the rear. I thought it was coming from the right rear tire but my girlfriend swears it's coming from the left rear tire so that makes me think it's starting at the diff. The best way I can describe it is it feels like I'm hitting a rumble strip for a second and the car pulls back. You can feel the resistance in the rear end and the tach drops in rpms. I made a video of the tach when it happens, this is a less severe occurrence then normal but I frigured a video would help more than me trying to explain it. Any help is appreciated. Thanks in advance.
I should also mention that there are no codes and the vibration occurs in all tranny modes, d, s d, and m. I thought it was the transmission for awhile but it doesn't do it under acceleration. It only seems to do it when i'm driving at a steady rpm.
Pantera7000 is offline   Reply With Quote
Old 03-19-2010, 09:53 PM   #2
Pantera7000
My Ride: 2000 323i
Thanks for all the "help" guys. Found the problem. Think I can press a new one in with a c clamp, alot of patience, and a breaker bar?
hope this helps someone else.
Old 04-04-2010, 08:55 AM   #3
Pantera7000
My Ride: 2000 323i
I hate to be the barer of bad news but I replaced my rear diff mount bushing and things have only gotten worse. The intermittent vibration is still there only worse but not only that I have a constant vibration all the time now. My new theory is it's a drive axle. left side.
Old 04-04-2010, 05:18 PM   #4
e46crooser
My Ride: 99 328 5spd
Look at your flex disc first. I have never seen a bmw axle cause a vibration that you are describing. If flex disc appears ok, then driveshaft could be culprit of vibration....
e46crooser is offline   Reply With Quote
Old 10-25-2010, 02:11 AM   #5
Pantera7000
My Ride: 2000 323i
update: changed out the rtabs to uuc rtabs. also changed the rotors thinking that was it but no luck. $130 dollars and a chemical burn later nothing.
