Sponsored by The Tire Rack
Old 03-17-2010, 09:43 AM   #1
Neeko
My Ride: e30 325is, 05 zhp
Getting some new wheels...need some advice please.
hi, i just got 05 330i zhp. i love the stock rims and all but im looking for a different look. from googling i know zhp rims are staggered 8" in the front and 8.5" in the rear. i found a nice set of rims that are 18x8 all around. my question is will i notice a difference in handling since the rear rims will be half an inch narrower?
i kinda like the thought of non-staggered since i can rotate my tires.
also will an offset of 35mm on a rim be ok? or will cause any issues?
Thanks alot, i own/owned many E30 but this is my first E46 so im still learning.
Neeko is offline   Reply With Quote
Old 03-17-2010, 12:06 PM   #2
ZZen330
My Ride: 2002 330Ci
18x8 et35 is no problem at all. Personally I like the staggered look but I do understand the rotation issue.
ZZen330 is offline   Reply With Quote
Old 03-17-2010, 02:14 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
You can run the 18x8 all around but I would go with staggered to fill out the rear. Non staggered wheels will be inset on the rear fender which will look odd.
We can do a set of 18" staggered VMR wheels with tires for you. CSLs are always a clean choice:
Old 03-17-2010, 02:39 PM   #4
Neeko
wow thats like the same car i have....u read my mind cause those are the same rims im looking for but.... im trying to find them in black with a red outside strip/lip.
got anything like that?
Old 03-17-2010, 02:42 PM   #5
Gheybe
Gheybe's Avatar
My Ride: F80 M3
EAS is the only one that carries other colors. Here you go bud: http://www.europeanautosource.com/pr...oducts_id=1145
somewhere in there they have the time attack rings you wanted.
Gheybe is offline   Reply With Quote
Old 03-17-2010, 02:46 PM   #6
Riverbmr3
My Ride: MB E350 & BMW 325i
good choice or you can check beyern mesh too!
Riverbmr3 is offline   Reply With Quote
Old 03-17-2010, 03:09 PM   #7
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Yep, we can do them in Matte Black with a Red Pin stripe.
Old 03-17-2010, 03:29 PM   #8
Neeko
thanks for the info and links guys. would 8.5" wide tires in the front be ok. would it cause any rubbing or issues?
Old 03-18-2010, 01:44 PM   #9
david @ eas
Past Site Sponsor
My Ride: E46 M3
Nope, no rubbing issues there. Go with the 18x8.5" or 19x8.5" all around on a ET40 offset or a ET35 offset and you'll be just alright. Here's a few colors we're offering for the CSL style wheels:
david @ eas is offline   Reply With Quote
Old 03-18-2010, 01:46 PM   #10
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
8.5" front is perfectly fine.
Old 03-19-2010, 09:39 AM   #11
Neeko
Ok, one last question...Would 9" wide rims cause any rubbing in either the front or the rear with a lowered zhp. its got H&R cup kit i believe.
thanks again
Old 03-19-2010, 09:42 AM   #12
BMWespresso
My Ride: 2005 325CI
me running 17x9 all around 245-40 + 5mm spacers no issues
BMWespresso is offline   Reply With Quote
Old 03-19-2010, 09:46 AM   #13
Neeko
is your car dropped?
Old 03-19-2010, 09:48 AM   #14
BMWespresso
My Ride: 2005 325CI
yeap, coils about and inch from OEM sports
