Sponsored by The Tire Rack
Old 03-18-2010, 12:19 AM   #1
CANDYnATL
My Ride: 2001 325i Sedan
Will these fit?
2001 sedan 18x8.5 et 35 front, 18x9.5 et 35 rear?
CANDYnATL is offline   Reply With Quote
Old 03-18-2010, 12:25 AM   #2
bmwdw8212
My Ride: e46 330ci
Fronts should be fine but as far as the rears, 9.5 +35 is on the aggressive side, rubbing issues may occur.
http://forum.e46fanatics.com/signaturepics/sigpic155362_3.gif
..../==========\........present
(]/______________\[) ..02 E46 330ci M-package
./(O8o]=()()=[o8O)\ .....97 R170 SLK230K
.|\====-----====/| .....past
[__|=========|__] .....92 & 93 E36 325i
bmwdw8212 is offline   Reply With Quote
Old 03-18-2010, 12:36 AM   #3
loong
My Ride: loves speedbumps
yes they will both fit. run a 235/40/18 front and a 245/35/18 rear.
loong is offline   Reply With Quote
Old 03-18-2010, 12:38 AM   #4
BSR423
My Ride: has fool coverage!
Do you have any pics of your car that you can post up?
Originally Posted by ChrisTKHarris View Post
F that, I'll buy a gun instead.
BSR423 is offline   Reply With Quote
Old 03-18-2010, 06:01 AM   #5
CANDYnATL
I can try to post one later. Im in a bind because the wheels I bought from JLevi are killing the rear of my car and I dont want any problems from now on. I have 19x9.5 et 40 back there. Im trying to downsize all the way around because they told me they would fit and they dont.
Old 03-18-2010, 10:40 AM   #6
f_t_s
My Ride: 2004 330ci
If you have a 19x9.5 et 40 on there now and it is "killing" the rear, going to an 18x9.5 et 35 is probably going to make your situation worse. An et 35 wheel will stick out 5mm (0.20 inches) more than the et 40 wheel.
I assume, when you say "killing" you mean the outer corner of the tire is rubbing on the fender/liner?
It doesn't matter much if you are running an 18" or 19" wheel. Once you put the proper size TIRE on the wheel the outer dimensions of the tire are about the same for both set ups.
What size TIRES do you have on the car now?
Some numbers for reference:
With a 19x9.5 wheel, you can mount a 265/30/19 tire (full wheel width fit & a 25.26" tire diameter) but that will be the most likely to rub. A narrower 255/30/19 for a lean fit (0.4" narrower & barely stretched, 25.1" diameter) a 245/35/19 skinny fit (stretched, 25.8" dia) or an anorexic 235/35/19 (max stretched, 25.5" dia) will all fit your 9.5" wide rim. Any tire diameter between 24.75 and 25.25 inches is pretty normal for our cars. Obviously wider tires and larger tire diameters will tend to rub more. Stretching the tire will reduce the installed diameter & width of the tire at the corners where they would normally rub first.
f_t_s is offline   Reply With Quote
Old 03-18-2010, 10:45 AM   #7
CANDYnATL
Does this sound better: For an e46 sedan, is offset 40 19x8.5 in the front and 19x9.5 45 in the back the guaranteed fitment for no rubbing? These are the ones I'm interested in.
Old 03-18-2010, 12:06 PM   #8
f_t_s
My Ride: 2004 330ci
That sounds correct. If the offset gets any larger than 45 with a 9.5 wide wheel in the rear I believe you risk rubbing on the inside of the tire.
Read this thread. The same question was asked & answered.
http://forum.e46fanatics.com/showthr...ht=19x9+offset
Nothing is guaranteed. If the tire you choose is too wide or has a very square profile or if the car is lowered it can still rub.
Old 03-18-2010, 12:13 PM   #9
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
This would fit fine at stock height with 235/255 combo.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
