Old 03-18-2010, 10:50 AM   #1
Bimmer_J
My Ride: 325ci
Oem Clutch Change
I have a question. Now I know that there is an appropriate clutch alignment tool however i cannot obtain one in the time frame that it is needed. The OEM clutch that is made by LUK has a SAC transport ring in it. I looked it up and it said do not take this off till you have the flywheel bolted to the car. My question is that if i take this off while its bolted will i still be able to line up the clutch or would i have to unbolt it and line it up?
09/11/01 343 Never Forget
Bimmer_J is offline   Reply With Quote
