Sponsored by The Tire Rack
Old 03-19-2010, 10:41 AM   #1
detto
My Ride: 328i bmw 07 /323i 00
HELP- Getting Rims..Need some advice
Sorry to post this again, but i need some help please. i have a 2000 323i and i'm getting some rims. i need to know if they will fit ok.
The rims are 17" bolt pattern is 5x120. The tires on there now from the seller are 215/40/17
Will the rims fit my car without issues? If so, what size tires should i get to put on there since i don't think the ones on it now will work.
I currently have potenza 225/45/R18 on my car and the fit perfectly.
Please help, need to make a decision on the rims today or else will be sold.
Thank you
detto is offline   Reply With Quote
Old 03-19-2010, 10:42 AM   #2
frobie15
My Ride: has a door star
Send a message via AIM to frobie15
You need to know the backspacing to know if they will fit without issue. With only a 215 width I doubt that the width of the wheel will be an issue.
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam
frobie15 is offline   Reply With Quote
Old 03-19-2010, 10:53 AM   #3
detto
whats the back spacing?
the description on the seller's blog is
"Rims were bought fo a bmw 318 but Will fit all 5 & 7 series cars bolt pattern 5 x 120 offset ET20 "
The rims were bought for a bmw 318
if its just the tire issus, no problem. I am fine changing the tires. I am only concerned about the rims fitting my car.
Old 03-19-2010, 11:17 AM   #4
frobie15
The ET20 means that the backspacing is 20mm. What's the width on the wheels? You might not be able to fit the width of tire that you want to run.
Thank you Sam
