Old 03-19-2010, 04:28 PM   #1
s1cke92
My Ride: e92 335i aw/cr 6mt
Send a message via AIM to s1cke92
my e46 330ci 2001 is throwing CEL and drive weird
hey guys, i just bought a e46 330ci for my little sister and the codes went off and drives weird. the codes are being thrown are:
P0619 Undefined Code
P0011 Camshaft Position - Timing Over Advance or System Performance (Bank 1)
P0444 Evaporative Emission Control System - Purge Control Valve Circuit Open
P0128 Coolant Temperature (Coolant Temperature Below Thermostat Regulating Temperature)
if anyone knows how to resolve these codes please post your thoughts.
TIA
s1cke92 is offline   Reply With Quote
Old 03-21-2010, 02:32 PM   #2
s1cke92
Anyone?
Old 03-21-2010, 02:40 PM   #3
phrozen06
phrozen06's Avatar
My Ride: E46, E92 M3, R32 VW
Send a message via Yahoo to phrozen06
Check your DISA Valve.
phrozen06 is offline   Reply With Quote
Old 03-22-2010, 05:58 PM   #4
s1cke92
i checked a youtube video about that and it doesnt make that sound. it has something to do with:
and that prolly triggers P0444 Evaporative Emission Control System - Purge Control Valve Circuit Open
Old 04-09-2010, 08:33 AM   #5
Nachos23
My Ride: 2009 335Xi Sedan
Send a message via MSN to Nachos23
Although I personally have not had an issue with the Camshaft position sensor, it apparently does fail. There are lots of threads in regards to this and the related codes/issues it creates when it fails....
My Rides:
2009 335i Xdrive
2000 Z3M Roadster
Nachos23 is offline   Reply With Quote
Old 04-09-2010, 02:46 PM   #6
e46crooser
My Ride: 99 328 5spd
Replace intake and exhaust cam position sensor and o-rings with OE bmw parts. Do not use junk vaico sensors, they will bite you in the a**. Also replace your thermostat too. Then clear codes. If the water pump hasn't been done, do that too since you'll be right there when doing the thermostat.
e46crooser is offline   Reply With Quote
Old 04-09-2010, 03:20 PM   #7
s1cke92
well someone should of post this before. i sold the car n took a lost of 1800 already.
