E46 Xi Forum
Old 03-22-2010, 06:39 PM   #1
bmwauug
My Ride: 325xi
$500 to install springs on an XI???
Hi - I tried three TireRack recommended installers and got $500+ quotes ton install springs on 2004 325xi!
I have heard this is a 2 hour job - WT*@*@*???
bmwauug is offline   Reply With Quote
Old 03-22-2010, 06:40 PM   #2
HyeWarrior
My Ride: '03 325i --> '13 GTI
$500 is WAY too much
Anything over $200 max is a rip
HyeWarrior is offline   Reply With Quote
Old 03-22-2010, 06:45 PM   #3
tb330
My Ride: 2008 Trailblazer SS
Yeah, that is absolutely ridiculous. If you can spare the time it isn't too hard to do them yourself. There's a DIY on here somewhere, just have to rent a spring compressor from Autozone and have a few tools handy.
tb330 is offline   Reply With Quote
Old 03-22-2010, 06:47 PM   #4
XIinSC
My Ride: 2003 325xi 98 M3
Did my XI in a little over an hour and I had no previous experience with the BMW setup.
I had a quote from a local shop for $200 and I thought that was too high.
XIinSC is offline   Reply With Quote
Old 03-22-2010, 07:33 PM   #5
xi_ter
My Ride: 2003 325xi
$500 is high. Use this DIY http://www.e46fanatics.com/howto/how...hp?howto_id=12
When I pulled out my rear springs, one was broken so I was glad I DIY'd.
Some stores like PartSource in Canada will lend a spring compressor free if you leave a deposit on your credit card.
Old 03-22-2010, 07:34 PM   #6
kz330xi
My Ride: 04 330xi...
i payed 150 and took 45 min
kz330xi is offline   Reply With Quote
Old 10-17-2010, 08:22 AM   #7
mp333
My Ride: 2003 325XI
How do you detemine when the springs needs to be replaced? Is when the car bounces around a bit too much, much noticable on a windy day.
My car feels a bit too loose on the highway.
mp333 is offline   Reply With Quote
Old 10-17-2010, 10:07 AM   #8
Mouf
My Ride: 2004 ZHP
the rears break.... alot.
Mouf is offline   Reply With Quote
Old 10-17-2010, 10:48 AM   #9
mp333
My Ride: 2003 325XI
How can you tell? What are the symptoms?
Old 10-17-2010, 07:10 PM   #10
Messe46
My Ride: 325xi ZSP - ONRLS
Send a message via AIM to Messe46
you can take off the rear wheels and look (not to be d!ck). also, the rear would look a little lower than 'normal'. taking a look only should take ~15min for each side (if you move slowly).
-Mike
“I’m sorry, but having an Aston Martin DB9 on the drive and not driving it is a bit like having Keira Knightley in your bed and sleeping on the couch. If you’ve got even half a scrotum it’s not going to happen.”
-Jeremy Clarkson
Messe46 is offline   Reply With Quote
Old 10-18-2010, 09:49 AM   #11
slimwest1
My Ride: 330xi
Has anyone actually paid $200 to have all four springs put on their car? I've called five indy's and the dealer and all of the labor time has been quoted pretty much the same....2-2.5 hours for the rears and 3-3.5 hours for the fronts. Even this forum says 1.5-2 hours for the rear ones alone. The average labor rate around here is $90/hour. I doubt anyone is going to spend min 5 hours labor on a car and only charge you $200.
slimwest1 is offline   Reply With Quote
Old 10-18-2010, 11:43 AM   #12
Messe46
when i was interning over the summer at my shop, it took about an 1-1.5 hours to do the rear on my car (we went at a normal pace) and took about 4-5 for the front b/c the left front bolt-head sheared off and it took a while to fix that one. the front right took about an hour or so (this is from what i can remember from june).
-Mike
-Jeremy Clarkson
Old 10-18-2010, 12:27 PM   #13
slimwest1
My Ride: 330xi
Well that sounds a little more in line with what I've heard (outside of the sheared bolt). I just ordered the Eibach Pro-Kit and Bilstein HD struts/shocks. I've heard that you can do the rears without a spring compressor so I'm tempted to try that myself. My wife says if I do it...it'll probably end up taking 3-4 hours and it's not worth me screaming the whole time. The quotes that I've been getting are just higher than I'd like.
Old 10-18-2010, 01:19 PM   #14
infinite012
My Ride: White '08 STI
I've been quoted 4-5 hours of labor when looking for shops to install springs on a Civic, a Miata, and a WRX. $90/hour * 5 hours sounds about right.
Just man the f up and DIY. The rears pull out and the fronts aren't bad at all.
infinite012 is offline   Reply With Quote
Old 10-18-2010, 02:01 PM   #15
Ivanhoe
My Ride: BMW 330 xi 2005
I do not know if this a stupid question, If I want to lower the car, after changing the front springs do I need to re-align ?
Ivanhoe is offline   Reply With Quote
Old 10-18-2010, 02:16 PM   #16
Ch40t1c
My Ride: 2002 330I BSM
Yes. You'll be able to drive on it but you may experience pulling to one side, excessive tire wear, etc. You'll want to get it aligned ASAP.
Ch40t1c is offline   Reply With Quote
Old 10-18-2010, 02:16 PM   #17
mvrk10256
My Ride: E30 325i
let me put it to you this way. realistically it takes about 2 hours for a regular person to do it sans air tools. It will take the shop 1-1.5 cause they have air/hydrolics - saves a **** ton of time compressing springs with air rather than using a socket set to compress the spring. but the fronts require quite a bit of dissassemble to yank out, so maybe 200 for all 4 does not seem insane coming from a guy who has done this quite a few times.
Old 10-18-2010, 02:24 PM   #18
howie
My Ride: CLK55 AMG, E90 335i
Send a message via AIM to howie Send a message via Yahoo to howie
I'll do it for $450
howie is offline   Reply With Quote
Old 10-18-2010, 11:21 PM   #19
Kubica
My Ride: 2003 325xi
$200-250 is a fair price.
Old 10-20-2010, 12:28 AM   #20
SharkmanBMW
My Ride: 03 330xi, 4th bimmer
Send a message via MSN to SharkmanBMW
Keep in mind some garages may charge $500 because it will actually take them twice as long as a competent mechanic
Also will depend where you are, but it's always worth seeking out the real BMW pros in the area, knowledge & experience is a must.
^°^ ><((({º>°° °°°
H&R Sport, Bilstein E46 Sport (Front), Bilstein E36 M3 Sport (Rear), Rogue Engineering RSMs
SharkmanBMW is offline   Reply With Quote
