Old 03-24-2010, 03:15 PM   #1
intense1
My Ride: '02 325i
Clutch for Auto-X?
Hi! Thanks for reading, this is my second post on this forum. I just got an '02 325i and it needs a clutch. I got the car because I want to start doing autoX, but I'm not sure of the rules. I think I'm going to be in stock or street touring. I read thru the rules on the SCCA webpage, but it wasn't clear to me if I could but a better than stock clutch in and still be compliant with the rules.
Thanks for the help!
intense1 is offline   Reply With Quote
Old 03-25-2010, 02:07 AM   #2
intense1
My Ride: '02 325i
anybody?
Old 03-25-2010, 02:16 AM   #3
mvrk10256
My Ride: E30 325i
put f1 gripforce into ebay. stage 2 w/ lightened flywheel, search on forum, god reviews
Old 03-25-2010, 01:12 PM   #4
Kubica
My Ride: 2003 325xi
I think it would be pretty difficult for someone to inspect your clutch at an autox and add points for an uprated one.
Have at it. Although most likely you will be in secong gear for most of the autox-proabably not going to make you faster, but I'm no expert.
Old 03-25-2010, 07:33 PM   #5
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
A lightened flywheel will definitely help you in autocross and someone would probably know if he pulled up to the start line with a chattering ultra-lightweight flywheel
SpeedDemon is offline   Reply With Quote
Old 03-25-2010, 07:38 PM   #6
mvrk10256
My Ride: E30 325i
ya but a stock 325 puts you squarely in C class so even with a few bolt ons, like a upgraded clutch or lgihened flywheel will nt cause you to move to a higher class. however a lightened flywheel adds 3 points, so you are at like 45 or so.
Old 03-25-2010, 07:44 PM   #7
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
i put down a lot of suspension and motor mods at my last autox along with good tires and wheels and different front bumper, i didnt even move up a class. i dont know what a clutch would do.
BMW Greensboro
BMW Service near your local independent BMW Greensboro BMW tech that has dealer-level expertise at a fraction of the cost. Check out our Per-Owned BMW for sale in Greensboro Near BMW Greensboro NC
Eurobahn BMW is offline   Reply With Quote
Old 03-25-2010, 07:53 PM   #8
mvrk10256
My Ride: E30 325i
shoskcs and springs are about 3 points total and you get a -1 for being a wagon.....
Old 03-25-2010, 08:34 PM   #9
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
just checked the rules for stock class
light weight flywheel is out but an upgraded clutch is fine provided the material is close to the stock material... no 4 or 6 puck clutches... has to be circular... i am one to follow rules, but i don't think an upgraded clutch is really going to give you a significant advantage in an autox and it is not easy to verify. go with what you want to lol.
Alternate components which are normally expendable and considered
replacement parts (e.g., engine and wheel bearings, seals, gaskets,
fi lters, belts, bolts, bulbs, batteries, brake rotors, clutch discs, pressure
plates, suspension bushings, drivetrain mounts, etc.) may be used provided
they are essentially identical to the standard parts (e.g. have the
same type, size, hardness, weight, material etc.), are used in the same
location, and provide no performance benefit.
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 03-25-2010, 10:43 PM   #10
intense1
My Ride: '02 325i
Thanks for all the info!! I was thinking that I'd be in 'stock touring', but what is C class? I've never actually done an AutoX
Old 03-25-2010, 11:07 PM   #11
azzy989
azzy989's Avatar
My Ride: 325i
you're running SCCA solo 2 right?
for a stock car, your actual class would be D stock provided you are 'stock' according to their rules. there are a few differences between a 'stock class' and 'street touring class' (ST)
stock class can run racing compound tires but they need to be mounted on the stock wheels, or the wheel needs to be same diameter and width as the stock wheel. modifications are very limited... off the top of my head, you can run a catback exhaust, aftermarket dampers and a front sway bar. nothing else...
ST class allows for a larger range of modifications. you can do pretty much any suspension mod. coilovers, f & r sway bars, camber plates, camber arms ETC ETC. the only rule about it is you cannot use spherical bearings in place of bushings. bushings can be upgraded to any stiffer material but the use of a solid/metal bushing is prohibited.....
NOW the advantage to ST is it is a street tire class, any tire with a treadwear rating of 140 and above is allowed. cars with racing compounds and a good driver of course have a bit more of an advantage than a car on street tires. the suspension modifications make ST kind of a ridiculous class to be in even though it is a street tire class....
having said that, there is another class that you could be in where you can be a bit more competitive. this class is A-Tire (AT). This is basically stock class but on street tires. that will help even the playing field a bit. when you register, your car will be classed as a "D-stock" car and then your sub class would be AT...
hope that helps some. let me know if you have any questions.
EDIT: a friend of mine told me that AT is a local class and it's availability will vary from chapter to chapter.... check to see if the hawaii chapter has it... if not i say run D-stock
Old 03-26-2010, 12:02 AM   #12
intense1
My Ride: '02 325i
Thanks! Super informative. BTW, what front bumper do you have? I have the regular one with the tiny fog lights and I don't like it.
Old 03-26-2010, 12:31 AM   #13
azzy989
azzy989's Avatar
My Ride: 325i
no problem!
i'm running the mtech 2 front bumper. yeap i used to have the bumper with the small foglights too. replaced it with the mtech a few years back.
Old 03-26-2010, 03:30 AM   #14
intense1
My Ride: '02 325i
Is that a BMW part or an aftermarket? I thought I saw some on Eaby for $200. (i know its off the thread topic-but it's my thread)
Old 03-26-2010, 04:28 AM   #15
azzy989
azzy989's Avatar
My Ride: 325i
it is a bmw part.
mine is OEM, but there are replica versions of the same bumper for a little bit less.
Old 03-26-2010, 08:23 AM   #16
Eurobahn BMW
Eurobahn BMW
how many points do you get for tokico blues?
you know what it doesn't matter, mods don't matter in HPDEs anyway.
BMW Greensboro
Old 03-26-2010, 11:15 AM   #17
wuzilla
My Ride: 2001 325it
Not to condone cheating in any way - but if you bolt on turbo kit, and still come in dead last, most likely no one will say anything. With something like a clutch, you would need a competitor to complain before having to actually explain your car. A little smidge of the rules here or there is harmless (in my opinion) unless you're going to the nationals or actually in the upper 70 percentile of your class. In other words, stop worrying about the fine print of the rules and go have fun!
wuzilla is offline   Reply With Quote
Old 03-26-2010, 01:30 PM   #18
xixixi
Banned User
My Ride: 01 330x-xi
3600 miles on this set up hard launches 4.5k rpm awd all grip no slip did 15 runs on a 1/4 dumping the clutch like a red headed step child! maybe 15 mins cool down after each run prolly less. I thought for a minute my clutch was burning but it was the pathetic mustang next to me. I can't say enough about this set up, just break it in right i didn't start "using the clutch" till after 2500 miles... IMO it's better to break in the clutch on downshifts not launches just my 2 cents
Old 03-27-2010, 03:01 AM   #19
M3it
My Ride: '02M3,325it,330Ci
For SCCA stock (DS) and street touring (STX) classes, the clutch has to stay stock. Rule is, if it doesn't say you can, you can't.
Dunlop Tires / GreenFilter / ChaseCam in car video / Bilstein shocks / Enkei wheels
M3it is offline   Reply With Quote
Old 03-27-2010, 05:30 PM   #20
azzy989
azzy989's Avatar
My Ride: 325i
^^ you can run an aftermarket clutch. i posted an excerpt from the rules above.
