Radiator Hose Leak - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-24-2010, 10:31 PM   #1
Toad21
My Ride: 00' 328CI
Radiator Hose Leak
I am starting to leak small amounts of coolant out of the under side of this hose:
It has leaked about 1/4 liter of fluid over 4 months, so I am not overly concerned about it, but I would like to fix it none the less.
1. Has anyone replaced and or reseated this hose?
2. I would also like to do a complete flush. Any coolants you guys recommend? Any cool flush out techniques?
Thank you for any intelligent input!
Toad21 is offline   Reply With Quote
Old 03-24-2010, 10:41 PM   #2
Zeekster64
My Ride: 2004 325i premium
Coolant Flush Procedure
http://www.bmw330ci.net/maintenance/coolant.php
Only use OEM BMW coolant with 50/50 distilled water
Zeekster64 is offline   Reply With Quote
Old 03-25-2010, 11:08 AM   #3
hummer
My Ride: 2001 330CI
Looks to me to be the o ring leaking on the temperature sensor.
Old 03-25-2010, 11:16 AM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Ditto on sensor o-ring.
I just asked about getting just the 0-ring and haven't heard...though someone just said today, getting just that was possible. Otherwise, new sensor comes with 0-ring.
One guy, Nathan, used a black 0-ring from an ass't of rings, so wouldn't have a particular size to share...but maybe someone will soon!
Doug
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 03-25-2010, 11:24 AM   #5
Zchild
My Ride: 2000 BMW 3XXi ZSP
Cool
+1,000,000 Dude, the O-ring in the temperature sensor has gone Tango Uniform. Just go to the Stealership get a new O-ring raise the hood, grab the sensor by the sides, push the sides and pull the sensor straight up, pull the old O-ring off replace it with the new one, push the sensor back into place and drive on... I replaced this in the Stealership parking lot, piece of cake. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 03-26-2010, 03:33 PM   #6
JibsBinx
My Ride: 330i
had the same problem a couple months ago, losing about the same amount of fluid. I didnt do a DIY but had a indie shop repair it for me. I bought the parts from pelican and had them replaced and had them do a coolant flush. The only thing i wish i did was replace the coolant expansion tank aslo. So if your going to replace the lower radiator hose, might as well do the upper hose and coolant expansion tank. And the reason for the leak was the O-ring for the sensor.
JibsBinx is offline   Reply With Quote
Old 03-26-2010, 07:16 PM   #7
bmwmike99
My Ride: 1999 323SE
Mine leaked at that spot - was the radiator warped to hell and starting to leak in that corner... worth checking also
bmwmike99 is offline   Reply With Quote
Old 03-27-2010, 01:36 AM   #8
Toad21
My Ride: 00' 328CI
Thank you guys for the info!
Isnt that sensor 0-ring under pressure? How can you do it in a parking lot on the fly when its under pressure? I would imagine I would need to replace it when the radiator is drained, right?
