Old 03-27-2010, 02:14 AM   #1
VERDUGO135
My Ride: E46//E39//ZX6R
Send a message via AIM to VERDUGO135
Tail light wiring problem help
ok so my friend has had this problem for a real long time hes gotten several tickets and doesnt know what to do to fix it. Im trying to go to the dealer with him to see if we can order this part does anyone know where i can order this from or have any experience fixing this?? basically the connectors are burned out and the wires have popped out of the connectors so its a pain in the asss everyday having to put them back in only to have them fall out again ... i was wondering where we could find this entire harness wiring with the new connector...
Originally Posted by djoutofsight View Post
GOOD SELLER!!! TRU TO HIS WORD AND I RESPECT THAT 100%!!!!
I will even buy a kidney from this guy!
E46....SOLD
E39.....SOLD
ZX6R.....SOLD
E90......SOLD
E60......SOLD
CLS500....SOLD
R1......CURRENT
CHALLENGER.....In the works
VERDUGO135 is offline   Reply With Quote
Old 03-27-2010, 04:13 AM   #2
PO-BoxE46
My Ride: BMW E46
i Had a tail light issue also. i found out how to fix it from a thread on the forum ill find the link again.
PO-BoxE46 is offline   Reply With Quote
Old 03-27-2010, 04:16 AM   #3
freerider
My Ride: 03 320i, 98 328i ind
I had the same problem with my previous e46, the entire back of the housing melted, luckily motorplan replaced the housings.
freerider is offline   Reply With Quote
Old 03-27-2010, 04:39 AM   #4
Alexotronic
Alexotronic's Avatar
My Ride: 2001 330Ci
I think it's a grounding issue. My left tail light was blinking fast, now is completely out. Currently researching solution as well.
I hear that maybe you can ground the light to the frame of your car. .. also maybe stripping the wires and directly connecting them to each other might work. (If you don't mind it being obama-rigged)
Alexotronic is offline   Reply With Quote
Old 03-27-2010, 08:39 AM   #5
dirtbike59
My Ride: 04 330ci
you gotta replace the black plastic plug, replace the what ever connectors went bad that slide into the plug, then add a second ground to the tail lamp assembly to prevent this from happening again. not hard to do if you have the skill to cut and crimp wires but you need the special pin remover tool to get all the wires out of the plastic housing without damaging them. I have all the stuff you need to fix it. unless the bulb hold got too melted.
dirtbike59 is offline   Reply With Quote
