Old 03-28-2010, 11:50 AM   #1
rob690
My Ride: 2002 325i sedan
front door speaker grills
My 2002 325i sedan has a cracked driver's side door speaker grill. Can I replace it and or if I upgrade to better speakers can I use the new grills provided with new speakers. And speaking of, what is the acutual size of door speaker I can put in the doors? I read 5.25 and 6.5 can fit, what is it? Are rear deck 6.5, read they were 4.
rob690 is offline   Reply With Quote
Old 03-28-2010, 11:21 PM   #2
Bandersnatch
My Ride: 2002 330 CiC
You should be able to find a new speaker grille. I'm not sure whether the dealer sells it separately, but you should check with them. Otherwise try eBay. Its doubtful that the grills supplied with a replacement speaker would fit.
The mid-bass speakers (the largest ones) in the doors have a very unusual mounting system with 3 screws. Fortunately Crutchfield makes an adapter that allows almost any 5 1/4 inch speaker to be used:
http://www.crutchfield.com/p_142SABW...s.html?tp=2824
The front door speakers are 160 mm in diameter which works out to about 6.3 inches. The rear deck speakers are the same as these, again with the oddball 3-screw mounting system.
Also these speakers are 2 ohms, which is a bit unusual. I replaced the rear deck speakers with Infinity Reference 6030's. I removed the plastic "basket" that the factory speakers fit into, cut off the mounting tabs on the speakers and silicone glued the speakers into the basket. Since the basket has the 3 oddball screw tabs, the new speakers dropped right in. Here's a DIY that was helpful, if complicated:
http://www.jumboprawn.net/jesse/projs/bmw_e46_audio.htm
In the front, I used the Crutchfield brackets and Infinity 5030's, their 5 1/4 inch speakers.
Another useful picture:
http://www.realoem.com/bmw/showparts...45&hg=51&fg=50
Originally Posted by DCJodon View Post
ZOMG HALP! *click*
oh hai, i can haz part numbro for florr matz? k thanxz.
Bandersnatch is offline   Reply With Quote
Old 03-29-2010, 08:55 AM   #3
Bandersnatch
Here's a better diagram that shows the speaker grill. It's only $9 from RealOEM. You can probably find it (or order it) at your local dealership too.
http://www.realoem.com/bmw/showparts...67&hg=65&fg=20
ZOMG HALP! *click*
Old 03-29-2010, 06:59 PM   #4
rob690
thanks, great info. ordered new grill.
