Old 03-31-2010, 11:42 AM   #1
bmwirl
My Ride: 320cd
Removing crankshaft pulley without crankshaft pulley removing tool!
Hi all. New member looking for some advice.
The rubber in the crankshaft pulley on my e46 320cd split and the outer rimmed circles sheared off. The crankshaft pulley is obviously still attached by the large bolt.
Is it easy to remove this without a crankshaft pulley removal tool, the one that fits around the teeth to stop them moving when wrenching the bolt off?
Also i tried to wrench off the bolt and the whole crankshaft moved a few cm's. I presume this wont have any effect on the timing??
Thanks for any info.
pics attached.
ID:	354217   Click image for larger version
ID:	354218   Click image for larger version
bmwirl is offline   Reply With Quote
Old 03-31-2010, 11:49 AM   #2
paraklas
My Ride: ESS TS2 320ci
No effect, get a big breaker bar and take it off. It's reverse threaded if I remember correctly.
Old 03-31-2010, 12:11 PM   #3
Chris-alfonso
My Ride: 330i
Originally Posted by paraklas View Post
no effect, get a big breaker bar and take it off. It's reverse threaded if i remember correctly.
+1
Chris-alfonso is offline   Reply With Quote
Old 03-31-2010, 12:14 PM   #4
///Orient3
My Ride: can't be defined
Not sure about the 320, but the 325 and 330 are not reverse threaded. Although, it looks to be a different design, so I can't say for sure.
[url=http://photos.e46fanatics.com/showphoto.php/photo/90077]
///Orient3 is offline   Reply With Quote
Old 03-31-2010, 12:27 PM   #5
darksideracer69
My Ride: 01 325ci
+2 shouldn't be that hard to do.
IMAG02051
Old 04-01-2010, 10:23 AM   #6
bmwirl
My Ride: 320cd
Thanks guys. So if i have ye right all i need to do is put a breaker bar onto the bolt and give it a whack with a hammer clockwise to release it. Once changed how would i go about tightening the bolt up to the correct torque with only a socket set. Thanks in advance.
Old 04-02-2010, 09:33 AM   #7
bmwirl
My Ride: 320cd
Ok have tried everything but cannot get that bolt released. Tried knocking it clockwise and anti-clockwise.
Anybody got any ideas?
Old 04-02-2010, 10:33 AM   #8
paraklas
I just checked, it's not reverse threaded.
Take a big breaker bar, have somebody in the car press the brakes (cause you will turn the whole engine before that bolt moves) put it in gear and then spin it
Old 04-02-2010, 11:17 AM   #9
bmwirl
My Ride: 320cd
Ahh very good. You sure yeah?
Its a UK import 2004 320cd (diesel)
Its automatic as well so will "pressing the brake" trick work, seeing as i cannot put it into gear??
Thanks.
Old 04-02-2010, 11:57 AM   #10
Luky
My Ride: '08 335i RIP'03 330i
Pull the radiator and try a impact wrench... Squirt some penetrating oil onto the threads... There is always the old trick of heating it up with a torch then the imact wrench, but I don't know if there are any rubber seals there that may be damaged.
Looks like there is a "castle nut" around it, See if you can wedge a long (lever) bar between the teeth to hold it and then hit the center bolt with the impact wrench or other long wrench with breaker bar.
Could also try sticking a rod/bar through the holes in the back of the pulley and see if you can hook it around/under part of the block to hold it while you turn the bolt with a BFR. Be careful not to pinch anything when doing this.
Luky is offline   Reply With Quote
Old 01-12-2013, 01:22 AM   #11
Alwekidson
My Ride: BMW 320d
Crank pulley
Hi
busy replacing the crank pulley on my 320d-2002, can any one help me by telling me do you loosen the bolt holding the pulley to the left or right.
Alwekidson is offline   Reply With Quote
Old 09-26-2014, 05:00 AM   #12
softers
My Ride: 320D
Right hand thread
I put mine in 6th, applied the brake with a lump of wood and used a 3/4 drive socket wrench and a length of scaffold pipe. it gave in eventually but I had to use the socket wrench ratchet to maximise the load applied. Definitely Normal Right hand thread on my E46 320D so anti-clockwise to undo.
Softers
softers is offline   Reply With Quote
Old 07-24-2016, 07:33 AM   #13
Ettie1
My Ride: E46 320d
Ettie1
I got mine loose by wedge-ing a torque wrench against the floor and then starting the engine.
Ettie1 is offline   Reply With Quote
Old 07-24-2016, 01:23 PM   #14
paraklas
Old 07-25-2016, 12:35 AM   #15
Mflara20
My Ride: 04 330i
It worked for the guy but I don't have the guts to do that.
Sent from my SM-G925P using Tapatalk
Mflara20 is offline   Reply With Quote
Old 07-25-2016, 02:46 AM   #16
Commando
My Ride: '02 325Ci MT '04 M3
Why would you use a torque wrench?
Commando is offline   Reply With Quote
Old 07-25-2016, 09:36 AM   #17
Poolman
My Ride: 525 BMW
There is a spot near the starter, that you can use a pin and lock the fly wheel in place, then you don't turn the engine when removing the crank bolt from he$$
Poolman is offline   Reply With Quote
