Old 04-09-2010, 05:19 AM   #21
wuj15
My Ride: 325I
bump anyone.
it's my only ride. Got no car to get around.
wuj15 is offline   Reply With Quote
Old 04-09-2010, 11:09 PM   #22
WFRFitness
My Ride: 2000 328CI E46
Originally Posted by wilcax View Post
well i gave in and took it to the stealer to have it diagnosed. BAD STARTER. they want 900+ to replace it, i'm having it towed back to my house and replacing it myself tomorrow. its not too common of a problem, and ive never had a starter give out on me with no warning before.
Good luck dude! I did this had it all the way out, took it in to have it tested and it tested fine you can get to both bolts from the top with a box wrench I believe it was a 3/8in. take you time and have patience it's not an easy job!
WFRFitness is offline   Reply With Quote
Old 04-09-2010, 11:11 PM   #23
WFRFitness
Originally Posted by wuj15 View Post
bump anyone.
If you really can't find anything searching start your own thread devoted to specifically this. you might have a real software issue tow it to the dealer have them diagnose it then fix it yourself if possible.
Old 04-28-2010, 03:06 PM   #24
BMW_Matt
My Ride: 135
bump anyone.
Make your own thread, and don't thread-jack OP's and you might get some help?
OP, have the same problem but I'm pretty sure it's the clutch safety switch. I can can get the car started by taking it off, putting it back on and trying to start, repeating and it will start. I might just suck it up and order a new one after checking through all fuses.
BMW_Matt is offline   Reply With Quote
Old 04-28-2010, 05:11 PM   #25
jinxie
My Ride: 2000 BMW 323ci
i've just recently had this happen to me... including the sometimes random starting. turned out to be the ignition switch... which after taxes and everything ran me $482 and some change at the dealer. i was taking it there anyways for the subframe issue... (mine was cracked and they replaced it)
jinxie is offline   Reply With Quote
