Thread Tools Search this Thread Rating: Thread Rating: 47 votes, 4.89 average. Display Modes
Old 02-22-2011, 10:20 PM   #61
blubayou
My Ride: 2003 Bluewater M3
Originally Posted by Karter01 View Post
Not bad for $6 bucks
Before:
After:
Hope you like it, 100% worth it in my opinion.
Looks good did you sand then paint the trim?
INDIVIDUAL BLUEWATER M3
blubayou is offline   Reply With Quote
Old 02-22-2011, 10:31 PM   #62
Karter01
My Ride: M3
Yes sanded down to a smooth surface, prepped and 3 coats of Plasti-Dip
Karter01 is offline   Reply With Quote
Old 04-04-2011, 11:24 AM   #63
2001BlackOnTan
My Ride: 2001 330Ci
I did this job a couple weeks ago and have been very pleased with the results. Very durable and hard finish, and no evidence of scratches underneath.
I removed all the factory coating with a razor blade -- I "strummed" across the surface with the blade held at 90 degrees to the surface and the coating came right off. Then I sanded with 400 grit sandpaper and primed with Duplicolor Self-Etching Primer (pea green cap) and several coats of Duplicolor Filler Primer (grey cap) (I probably could have easily gotten away with using just the Filler Primer). I sanded with 1000 and 1500 sandpaper and re-primed several times until I got a flawless surface. I finished with multiple coats of Duplicolor Vinyl & Fabric Coating and let the final coat dry overnight.
Removing the console from the dash is very easy and well worth the time and effort. No need to buy a new parts. It's easy to remove the switches from between the two compartments.
For those wondering about the chrome strips on the doors, those had gotten discolored long ago, so I just painted over them. Duplicolor does make a chrome product but I decided not to worry about it.
2001BlackOnTan is offline   Reply With Quote
Old 04-11-2011, 09:36 PM   #64
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
How do you remove the rubber coating? Having a hard time removing all of it
phamine is offline   Reply With Quote
Old 04-11-2011, 10:18 PM   #65
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
Here is the link to clean/remove rubber coating on your center console.
Thanks to delmarco for putting together another GREAT DIY!
http://forum.e46fanatics.com/showthr...center+console
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 04-11-2011, 10:59 PM   #66
dsblk93gt
My Ride: '01 325i
delmarco, nice job! If you find a tan to match the interior let me know I need to fix my console!
'01 325i Sedan - Alpine White, Sport Package, 5spd - daily driver 144k miles
'93 Mustang LX 5.0 - Reef Blue, 5spd, Vortech Si-Trim and alot more....
dsblk93gt is offline   Reply With Quote
Old 04-11-2011, 11:02 PM   #67
sellsellsell2000
My Ride: E46 seden
I guess you can apply 'CLEAR' Plasti Dip over your tan console after you've removed the old film. The CLEAR are transparent, is worth a shot.
BMW /// 323i
Old 07-21-2011, 10:41 PM   #68
F4rcry52
My Ride: 2002 330i
Are you olaf from YouTube?
Sent from my ADR6400L using Bimmer App
F4rcry52 is offline   Reply With Quote
Old 08-03-2011, 06:52 PM   #69
2002E46NH
My Ride: 2002 325i
Delmarco - another great DIY from you. My console looks 1000 times better now. Like New! Thanks!
2002E46NH is offline   Reply With Quote
Old 10-28-2011, 05:12 PM   #70
macca
My Ride: 2003 e46 318i
Hey Delmarco on image 7 on page 1, just wondering how you took the little door off of that to access those screws??? -thanks
P.S. this plasti dip **** is amazing!!
Yeah BUDDY!
macca is offline   Reply With Quote
Old 10-31-2011, 07:10 PM   #71
325xittt
My Ride: 2003, 325 XIT
FYI If you do use the Platic Coat and don't like how it looks you can remove it easily and completely. Spray the surface with starting fluid and wipe it away. it comes off easy and leaves no trace.
325xittt is offline   Reply With Quote
Old 11-18-2011, 12:00 PM   #72
ShwnD
My Ride: 325i
HAHAHAHA I was thinking the same..
ShwnD is offline   Reply With Quote
Old 11-29-2011, 03:01 PM   #73
Yert90
My Ride: 2002 325i
Originally Posted by delmarco View Post
What happens in the missing pic? How do you get the door off to remove the top 2 screws?
Yert90 is offline   Reply With Quote
Old 11-30-2011, 01:32 AM   #74
macca
you open it up then just pull on the door and it'll pop right out!
Yeah BUDDY!
Old 11-30-2011, 03:41 PM   #75
Yert90
My Ride: 2002 325i
Haha. thanks... I got it.
Old 12-17-2011, 07:35 PM   #76
InterlagosBlau
My Ride: 2001 325Ci
This is awesome! On my way to homedepot now
If you can't be good, be good at it!
InterlagosBlau is offline   Reply With Quote
Old 03-22-2012, 05:47 PM   #77
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
Thanks. Just did mine over the week. Will be putting my pieces back in tomorrow
sanded/taped
Since I had read a lot of fuss about whether Plasti-Dip will last or not I took a few extra steps just in case.
Used Filler Primer at a friends suggestion.
After that dried (about 10 mins) I applied Adhesion Promoter
then sprayed plasti-dip over. The Adhesion Promoter said to do about 2-3 coats and about 3 mins after (however many coats you choose to do) the second coat I applied the paint. I followed those instructions and liked how how the pieces turned out. Image after 2nd coat
Finished
Will update with another photo after pieces are put back into the car. (Excited for tomorrow hahaha)
omni01_k is offline   Reply With Quote
Old 03-22-2012, 10:13 PM   #78
Ivanhoe
My Ride: BMW 330 xi 2005
Nice, looks great
Ivanhoe is offline   Reply With Quote
Old 03-22-2012, 10:34 PM   #79
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
Originally Posted by Ivanhoe View Post
Nice, looks great
Thank you.
Old 03-23-2012, 12:32 AM   #80
illestminimike
My Ride: Project Drama
Doing this on Saturday.
