Old 04-02-2010, 10:54 AM   #1
am420190
My Ride: '04 325ci
Anyone know how to change out Corner Reflectors on a Facelifted E46?
Does anyone know how to change out the Corner Reflectors on a Facelifted E46? I am not sure if they just snap out or if there is a trick to it.
am420190 is offline   Reply With Quote
Old 04-02-2010, 10:58 AM   #2
TiAgTouring
My Ride: has a D-Pillar
you have to loosen the bolts for the headlights. There are 3-4 bolts that hold the headlights in.
You also have to take out the narrow body panel under the headlights (just snaps out)
Once you can pull the whole headlight housing out, the corners slide out. (they lock into the main headlight housing)
There are plenty of DIYs if you need more help, just
TiAgTouring is offline   Reply With Quote
Old 04-02-2010, 11:03 AM   #3
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
If you're talking about the reflectors on the bumper. Just get your fingernails under the top, push down, and then pull straight out.
-Gary
DiscoStu is offline   Reply With Quote
Old 04-02-2010, 11:08 AM   #4
alibusoul
My Ride: 04 330Ci
He has a facelift, it doesn't work that way.. and he might be talking about the bumper reflectors
alibusoul is offline   Reply With Quote
Old 04-02-2010, 11:14 AM   #5
Define ///M3
My Ride: E92
Wrong, the corner REFLECTORS on a facelift can be taken out by getting a SMALL flathead screwdriver and a towel, press down on them and they will pop outwards, just be steady and careful
Define M3
tiag 2000 323ci - sold
BSM 2004 325ci - sold
AW 2013 328i - sold
MWM 2012 e92 328i - current
Looking 4 e46 M3
Define ///M3 is offline   Reply With Quote
Old 04-02-2010, 11:16 AM   #6
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
OP can you show us a pic or diagram of what your talking about.....I don't think we yet understand what part your trying to remove.
Bimmer4Lyfe is offline   Reply With Quote
Old 04-02-2010, 11:19 AM   #7
SoBo330ci
My Ride: 3 pedal 3.0 facelift
Slide a credit card along the top of the reflector. Once you get it wedged in there, stick your finger behind the card and push out and down. The reflector should pop right out.
Getting the old ones out is the easy part. I ordered clear reflectors from Jlevi, and had to do some serious sanding to the various tabs and clips before they barely popped in. Then still managed to chip a tiny bit of the passenger side reflector.
'05 330ci sport Graphite Metallic
'97 318ti Hellrot - RIP
constantly lurking
SoBo330ci is offline   Reply With Quote
Old 04-02-2010, 04:21 PM   #8
am420190
My Ride: '04 325ci
Thanks guys, just wanted to make sure there wasn't a crazy trick to it
Old 04-02-2010, 05:31 PM   #9
elanlyfestyle
My Ride: 03 325ci
lol ^^^^Like he said be very careful i ended up completly braking my brand new one in half during install and the paint on the bumper started cracking as well. So be careful!
elanlyfestyle is offline   Reply With Quote
Old 05-07-2010, 05:51 PM   #10
theinfamousdrew
My Ride: 911 Turbo / E70
Bumper Reflectors = PITA!!!!!
I just installed mine...broke an oem one.....and chipped both on install....never again! (until i order new ones to replace the chipped ones)
theinfamousdrew is offline   Reply With Quote
Old 05-07-2010, 06:14 PM   #11
My325XI
My Ride: 03 325XI Sprt Prem
Per a modbargins description...
Fitment (Please consult your owner's manual for your application fitment type)
-99-01 (push in)
-02-05 (screw in)
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
