Sponsored by The Tire Rack
Old 04-05-2010, 10:44 PM   #1
e46JAB
My Ride: Titan over Tannin
Wheels rubbing (inner fender, not lip)
After I put my 19's on I noticed under heavy loads (one or more passengers) over dips and under hard acceleration I noticed rubbing coming from the rear of my car. My fenders have been rolled so I didn't know why it was rubbing. Anyways when I checked it out I realized it was rubbing deeper into the wheel well, not the fender lip. What are my options for fixing this. The only thing I can come up with is either bigger bumpstops or get a stiffer suspension (dampening adjustable). I'm running stock bumpstops that are modified for lower suspension. Any other pointers?
e46JAB is offline   Reply With Quote
Old 04-06-2010, 12:39 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
So the tire is rubbing on the inner wheel well? Any pics? What size tire are you running?
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-06-2010, 01:41 PM   #3
e46JAB
The tire is rubbing the top of the wheel well. I'm going to do this Friday it should be the trick: http://forum.e46fanatics.com/showthr...382&highlight=
Old 04-10-2010, 10:52 AM   #4
shynebrite
My Ride: '04 330CI ZHP
What size spacers you running, 10mm in the rear with 9.5 et 45?
shynebrite is offline   Reply With Quote
Old 04-10-2010, 03:04 PM   #5
Penguin Koolaid
Banned
My Ride: Inline Six
What size tires are you running?
Penguin Koolaid is offline   Reply With Quote
Old 04-10-2010, 05:47 PM   #6
cd330
ModZombie Moderator
cd330's Avatar
My Ride: SG E46, AW F30
seriously, how did i never see that diy in all my rubbing research and issues. Def going to try this.
OP, i have the same issue even after I cut my fender lips off. it rubs above where the lip is, not where the lip used to be.
cd330 is offline   Reply With Quote
Old 04-12-2010, 02:24 PM   #7
e46JAB
Did that diy before 4ngiefest. Worked like a charm! Two passengers hard driving and zero rubbing. And all for five bucks! Right now I'm running 9.5 inch rears et45 with 255s. I ll be putting on 10mm spacers whenever they finally come in
Old 04-12-2010, 02:25 PM   #8
lllSupra
My Ride: E46 330i
I think its rubbing where the rear bumper meets the quarter panel.. thats what mine did and it eventually shaved the inner part off and runs just fine now
lllSupra is offline   Reply With Quote
Old 04-12-2010, 08:57 PM   #9
e46JAB
It was rubbing the top of the wheel well under hard acceleration and under heavy load, the bumpstop DIY fixed the problem.
Old 04-13-2010, 12:37 PM   #10
VMRWheels
VMRWheels's Avatar
Great to know the simple mod helped cure the issue.
Hows the ride comfort?
-Charles@VMRWheels
Old 04-13-2010, 03:38 PM   #11
e46JAB
Ride comfort has not changed. I have not noticed when the shock would bottom out on the new bumpstop. They are rubber but there is still some forgiveness in them which helps.
