Old 04-06-2010, 04:47 AM   #1
Tlvivo
My Ride: 320i Individual
Unhappy Need help - car not starting
Peeps i need help - my 320i AT is not starting, before it happened my brother was playing sound when he was chilling with his friends. Battery ran low but car started after leaving it off for about 20 minutes. Started the car let it idle while getting ready to drive it - came back about 10 min later and the car had switched itself off. Tried starting the car nothing, it cranks but does not take... Any ideas????
Side note - while the car was idling - my drunken uncle revved the **** out the car... I was really pissed off (this was before it switched off)!!
I have tried boosting the car - nothing!
Tlvivo is offline   Reply With Quote
Old 04-09-2010, 03:49 PM   #2
e46crooser
My Ride: 99 328 5spd
check if fuel pump is running....under rear seat.
e46crooser is offline   Reply With Quote
Old 04-09-2010, 03:52 PM   #3
MP325
My Ride: 2004 325xi
do you have gas?
MP325 is offline   Reply With Quote
Old 04-12-2010, 08:11 AM   #4
Tlvivo
LOL - Yes I have gas...
The fuel pump is also running, there no warning lights on the dash, the interior lights are shinning bright so the battery is still in tact..
I havent had time to take the car to my mech, but it seems I will have to since I am still baffled and no one seems to be sure what could be wrong.
Old 04-16-2010, 06:15 PM   #5
AutomanTurk
My Ride: '03 330i, '06 325i
had a problem with mine earlier in the month...anyone work on the computer unit under the front? turned out mine was replaced before i bought it and he used a wire from another car which didnt fit correctly and fell out partially from the unit..so when it touched it would start and wouldnt if it didnt
AutomanTurk is offline   Reply With Quote
