Old 04-06-2010, 08:01 PM   #1
Radi27
My Ride: 2004 330xi
2004 330xi has rough idle--need help please
Hi, I recently purchased a 2004 330xi, with less than 50k miles from a Lexus dealer. I drove it approximately 250 miles home, then maybe another 50 miles rountrip. When the car is in park, it has a strange noise, like a belt or something might be loose. At first, I thought it was just when the AC was on (which I thought might be further proof of a belt issue), but I was wrong. It is like that all the time. If I accelerate, it goes away. Any ideas? I am not a huge tech guy, but I was hoping to avoid a dealer, especially given I just got the thing. Any suggestions would be appreciated. New to the board, so thanks for the help.
Radi27 is offline   Reply With Quote
Old 04-09-2010, 07:51 AM   #2
Nachos23
My Ride: 2009 335Xi Sedan
Send a message via MSN to Nachos23
I have an 04 300Xi that was experiencing a weird "squeeking" sound almost constantly... We replaced piece-by-piece the parts driven or in contact with main drive belt (not AC belt) and it turned out to be my mechanical tensioner. Sounded fine when the belt was off and spun normally, but attach the belt and the noise came back. We replaced, idler, water pump and alternator forst because it DID NOT sound like a tensioner issue.... squeek gone now. Could just be your belt. Get some talcom powder and lightly dust it over all the components on the drive and AC belts. See if weird noise goes away. Dust each piece separately (water pump, alternator, idler, tensioner, AC compressor and harmonic balancer (main drive for both belts) and then the belts themselves. If the dusting causes the weird noise to go away, determine which piece it was and change it.... Could be a bad belt too....
My Rides:
2009 335i Xdrive
2000 Z3M Roadster
Nachos23 is offline   Reply With Quote
Old 04-09-2010, 11:17 AM   #3
e46bonestock
My Ride: 325
+1
the belt tensioner is one of the biggest oversights ever when replacing the belts. There's a tech video on youtube. Even if its still smooth, if you spin it, and you hear it, the tensioner pulley is dry and will fail soon. When you change your belts, it's a good idea to change the belt tensioner.
e46bonestock is offline   Reply With Quote
Old 04-09-2010, 12:36 PM   #4
Radi27
My Ride: 2004 330xi
Thanks!
I will definitely take these suggestions and see what I can do. I appreciate the help. Thanks!
Old 04-09-2010, 01:39 PM   #5
Nachos23
actually mine spun perfectly normal. I actually think the sqeek came from the tensioner assembly itself.... likely a little rust or corrosion starting.... we had spun all the bearings the first time we pulled the main belt and the idler needed replacing.... but all others sounded fine. thats why we ended up changing out the other pieces first, because there was NO sound coming from tensioner when spinning. Sound only returned when belt reinstalled.....became a process of elimination. last part to try was tensioner, but I replaced entire tensioner from another engine he had rather than messing around further. That did the trick. Likely why BMW moved to hydralic tensioners.
My Rides:
2009 335i Xdrive
2000 Z3M Roadster
