Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 09-23-2010, 06:14 AM   #241
profor
My Ride: E46 320d 2003
Joker
E46 320d Touring 2003 - Autounlock after key is turned off, seat heating from Skoda OII, Instrument Cluster mods by Scott87, Trippling on turn signal lights, some repairs on GM with broken CL relays
profor is offline   Reply With Quote
Old 09-23-2010, 06:16 AM   #242
DNA1010
My Ride: 325xi
Originally Posted by profor View Post
hey, what is it good for and how do you light it up?
I think he's showing us he put the LEDs directly under the faceplate. You have white LEDs so your red stays red. He's using blue which make the red purple and dim.
DNA1010 is offline   Reply With Quote
Old 09-23-2010, 06:59 AM   #243
profor
Yes, that is clear
Old 09-23-2010, 07:19 AM   #244
manzrik
My Ride: e46 320d
manzrik is offline   Reply With Quote
Old 09-23-2010, 07:29 AM   #245
profor
OK how do You control it?
Old 09-23-2010, 07:57 AM   #246
manzrik
My Ride: e46 320d
i have to finish the shift light pcb...
Old 09-23-2010, 08:21 AM   #247
profor
Ou jeah need help? You know how cute PCBs can i do
Old 09-23-2010, 05:38 PM   #248
manzrik
My Ride: e46 320d
Old 09-23-2010, 05:56 PM   #249
profor
Hehe clever Did You measured with oscilloscope the speedo signal?
Ach today realized that i love my cluster whiteeeeeee rulez!
ID:	376835   Click image for larger version
ID:	376836   Click image for larger version
Old 09-23-2010, 07:25 PM   #250
XANDERCOM
My Ride: E46 318i SE
Originally Posted by xGeegx View Post
This is EXACTLY what I wanted to do with my car! Ha, I had this picture in my mind for 2 years and now its in front of me! Blue dash, aircon, a soft glow coming from under the dash, and all of the other buttons blue, aluminum looking gauges, and aluminum colored trim! I hope you don't mind me "copying" but I was going to do it anyway So any tutorials for the Aircon, or any of the other buttons in the car that light up with default orange?
Once you do the dash you will be confident enough to explore other parts of the car using the same method.. its pretty easy, i was a bit scared at first.
The aircon unit will actually pop out without any screws, then just disconnect the harness at the back.
XANDERCOM is offline   Reply With Quote
Old 09-24-2010, 07:13 AM   #251
manzrik
My Ride: e46 320d
I know the signal into DDE, 4 pulses/rpm...(information by TIS,320d 136hp with vp44 pump)
Old 10-10-2010, 01:00 PM   #252
1st_ID_Vet
My Ride: 2004 325XI
Wow, you guys are pro's. I am going to have to work up to this, soldering is certainly something that I should know by now...but don't.
1st_ID_Vet is offline   Reply With Quote
Old 10-10-2010, 04:23 PM   #253
sillieidiot
My Ride: '06 AW 330ci
jw, but do most of you guys have sedans? because they have black guage faces while the coupes have grey
Old 10-10-2010, 04:27 PM   #254
jinxie
My Ride: 2000 BMW 323ci
i thought only the ///Ms were grey. mine is black on a coupe...
i think
jinxie is offline   Reply With Quote
Old 10-10-2010, 04:54 PM   #255
sillieidiot
mines grey. it's like dark grey. the only time you could tell is in direct sunlight or when you have the cluster outside. i thought it was black, but nope.
Old 10-11-2010, 03:38 PM   #256
jinxie
yea i just took a look today and you're right! had me fooled though.
i hope it will look okay when i do this mod, i need to order new white LEDs because i got the super bright ones by mistake.
Old 11-02-2010, 07:11 PM   #257
manzrik
My Ride: e46 320d
Old 12-14-2010, 03:22 PM   #258
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
Free bump for a good thread!
Also a question for profor and manzrik: any chance of combining your two needle-lighting mods into one DIY like profor's pdf document with the needle-mounted position? The white needles on a colored dial looks awesome. I plan to keep the OEM orange backlighting (and do black on the back of the dial) and do the white needles but I'm a bit unsure of the wiring when the two methods are combined.
Since manzrik's method uses 4 LEDs in series, the resistors used in profor's writeup would no longer work. Also, is there a place to wire in the LEDs so that they dim with the rest of the car? Right now I have the Dynavin V5 that doesn't dim so things are at full bright to match, but I'd like to preserve the functionality.
Both the blue and white backlighting jobs look awesome. But I'd go crazy and HAVE to do the whole car so that's not an option for me. (OCD much?)
Oh, and what wattage soldering iron do you recommend? I soldered a modchip into an Xbox but lifted a trace in the process. That was a ROYAL PITA to fix and I don't want to repeat it with my car.
Again, great job!
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 12-14-2010, 03:41 PM   #259
sillieidiot
i wish they could find a way to do the white lcd lol
Old 12-18-2010, 07:14 PM   #260
TR4G-
My Ride: '01 325xi, '90 325iC
Ok so quick question. I didn't get to read through all 13 pages so it might have been answered:
A) how do you tell the polarity of the existing LEDs? (I'm assuming negative is the side with the small - but I am not sure)
B) what type of Surface mount LEDs are already there?
C) (most important) will 0603 110mcd 20mA 3.3V LEDs work? I have 8 blue ones already so would I be able to use these guys? (yeah I know they're small, but I have nimble fingers)
TR4G- is offline   Reply With Quote
