Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 04-30-2011, 02:03 PM   #401
Pat-UK
My Ride: 325i Auto
Send a message via ICQ to Pat-UK
Here's another usefull link, pretty accurate without you having to do all the math
http://led.linear1.org/led.wiz/
Pat-UK is offline   Reply With Quote
Old 05-10-2011, 12:47 AM   #402
jkl
My Ride: 330i ZHP Imolarot2
Originally Posted by infinite012 View Post
The cluster is done. I finished the LED swap in about an hour and a half (or however long Megamind is). For the LCDs, I doubled up on cut printer paper (fold paper in half, cut at the crease = double layer of paper) and replaced the white/orange gel with the paper. Hooray for autotragic because I had to do this twice.
Reminding myself to remember which way the LEDs point
Finished
Not so finished
Thanks for this thread and the other one in the DIY section for giving me motivation to tear apart the car!
Hey guys, how do you perform a full light/needle cluster test?
jkl is offline   Reply With Quote
Old 05-13-2011, 11:01 AM   #403
manzrik
My Ride: e46 320d
a photo of my interior
manzrik is offline   Reply With Quote
Old 06-13-2011, 08:26 AM   #404
JerzyBoy973
My Ride: 01 330ci
subscribed to find later
JerzyBoy973 is offline   Reply With Quote
Old 06-24-2011, 09:05 AM   #405
sweetcheeks1988
My Ride: 320 d
Can anyone tell me the sequence of the LEDs on odometer I messed it up
Managed to get everything else working
sweetcheeks1988 is offline   Reply With Quote
Old 06-24-2011, 10:23 AM   #406
taurus_tem
My Ride: Bmw 318 M Sport Conv
Have you had a look through all the posts on this topic? i'm sure it is there shown as picture.
taurus_tem is offline   Reply With Quote
Old 06-24-2011, 10:59 AM   #407
infinite012
My Ride: White '08 STI
Did you see my post above? It has a high res image of the cluster PCB. You can probably make out the orientation of the LEDs from that.
Wow, you made it even smaller.
Here's an ultra-high resolution image: http://my-xi.com/pictures/led/IMG_7261.jpg
I also don't see how you could have messed this up. If one of the LEDs is out, then it's going to be a pain to figure out which one, so I suggest powering each one (i.e. testing) individually before soldering onto the PCB.
infinite012 is offline   Reply With Quote
Old 06-24-2011, 02:08 PM   #408
sweetcheeks1988
My Ride: 320 d
I started on page 1 and went through gave up half way and searched else where
Got 12 hour shift at work tomorrow but will look back through sun so hopefully
Got abit more done today did steering wheel havnt seen it in the dark yet but went with White LEDs cause ran outta blue but think will it look good
Old 06-24-2011, 04:42 PM   #409
sweetcheeks1988
My Ride: 320 d
Alright found your pic thanks infinite012 And eurorush for marking them
Now jus gotta order more LEDs !
Old 06-25-2011, 04:42 PM   #410
sweetcheeks1988
My Ride: 320 d
I got around to taking the pic very happy with the result as works with the silver trim
Old 07-05-2011, 04:55 PM   #411
Budda9
My Ride: 2011 VW Golf
Amazing work all, i think i just found my next mod
2003 - Orient Blue 325i : Orion Lite AEs - Otherwise stock
Budda9 is offline   Reply With Quote
Old 07-06-2011, 04:40 AM   #412
sweetcheeks1988
My Ride: 320 d
LEDs came through post and finally fixed the odometer !
Also if u noticed changed my mini car on dash to White
Now just have to do the centre console
Old 07-06-2011, 06:15 AM   #413
infinite012
Cool, but your tachometer is much too low to be useful...
Old 07-06-2011, 07:58 AM   #414
sweetcheeks1988
My Ride: 320 d
Nah it's ok didn't have lights turned on was just displaying my odometer and that I got it working will get a pic of the whole set up later
My needles aren't 100% working fuel and temp working, pretty sure speed is alright too but my rev needle is off need to go back and read up on it understand few people had problems with it
It drops below the Mark and once engine is turn on sits at the .5 Mark
Also might of went too heavy on the sharpie mod couldn't get red sharpie at local store but said any old red marker will do I was wrong they won't illuminate now gotta try get some of the marker off
Old 07-06-2011, 08:05 AM   #415
sweetcheeks1988
My Ride: 320 d
http://forum.e46fanatics.com/showthread.php?t=855402
what i spent rest of the day doing cheap easy mod !
not fully finnished need to go back and hide the wiring better behind carpet didnt give it my full effort real excuse is i didnt wanna lift out the sub ha feeling lazy
Old 07-06-2011, 11:33 AM   #416
sweetcheeks1988
My Ride: 320 d
Pic with tachometer turned up
Old 07-07-2011, 06:07 PM   #417
sweetcheeks1988
My Ride: 320 d
Here's my problem at night can't see needles ha ha
Also a pic of the trunk I modded in the link above
Old 07-07-2011, 08:55 PM   #418
eurorush86
My Ride: 2000 BMW 323i
I took my gauges out to the car probably 5 times before putting the bezel and case on it, to turn the car on and adjust the needles to the correct places. once they go where they belong and stay there, put it all back together and your good to go =D
Rokkor Coilovers-All Meyle HD Under the Car-Hotchkis Sways
Angel Eyes- Smoked lights-18" wheels with Falken Tires
Shaved Trunk-Tint-Exhaust/Intake-Europlate
Sparco + Suede Interior- Heavy Foot...
eurorush86 is offline   Reply With Quote
Old 07-10-2011, 09:34 PM   #419
infinite012
When you put the needles back on, make sure to spin them on counter clockwise. That way wherever you spin them to, they will "set" at that position.
Old 08-03-2011, 03:49 PM   #420
sweetcheeks1988
My Ride: 320 d
What I did today
Took around 2 hours
Footwell LEDs
ID:	411432   Click image for larger version
ID:	411433   Click image for larger version
