Sponsored by The Tire Rack
Old 04-08-2010, 05:39 PM   #1
Sam 330ci
My Ride: 03 530i 07 Sierra
Send a message via AIM to Sam 330ci
Thumbs down new suspension > alignment > new tires > bad alignment?
I put a new suspension on my car a 3 weeks ago - Meyle HD Arms and Bushings/Bilstein Sports/H&R Race. All was installed professionally, and afterwards had a professional alignment. The car was on snows (ContiWinterContact 225/45 17 all around) at the time and rode PERFECTLY for 3 weeks.
Flash forward to Wednesday, 2 days ago. Put on my summer tires - Goodyear Eagle F1 225/45 17 Fronts and General Exclaim UHP 245/40 17 rears.
The front left Goodyear and 2 rear Generals are all 90% tread, the front right Goodyear is new - see this thread for an explanation on why it's new:
http://forum.e46fanatics.com/showthr...town+fair+tire
Anyways, now the car is absolutely all over the place. Tram lining like crazy, pulling to the right and the left, wheel is vibrating at times, it's mind-boggling.
Would changing tires cause the need for another alignment? Should I not be running two different fronts and rears? I was told I'd be fine with these two types of tires as long as the axles matched.
Any would be greatly appreciated. Thanks.
Sam 330ci is offline   Reply With Quote
Old 04-08-2010, 05:44 PM   #2
remedys
My Ride: 2006 BMW 325CI
Do you have the summers and winters on different rims? If so maybe you need to balance your tires, and if you had them changed off the same rim it could still be a balance issue, possible they didn't balance correctly.
remedys is offline   Reply With Quote
Old 04-08-2010, 05:45 PM   #3
Sam 330ci
They are on the same wheels.
Old 04-08-2010, 07:33 PM   #4
Sam 330ci
Anyone else have an opinion?
Old 04-08-2010, 08:01 PM   #5
jzwu
My Ride: 2005 BMW 330Cic
Change back to the winter tires and see what happens. You pay a small mounting cost.
jzwu is offline   Reply With Quote
Old 04-09-2010, 06:41 AM   #6
Sam 330ci
^That won't solve the problem though. Any one else?
Old 04-10-2010, 03:39 PM   #7
mccoy
My Ride: BMW E46 M
Hi
Try up your suspension in 10 mm, if this solve the problem tell me.
Best Regards.
mccoy is offline   Reply With Quote
Old 04-10-2010, 03:44 PM   #8
mdon
My Ride: 325i
i think the tires u r running have to do with that problem...
usually if u run different tires...
it must be 2 identical front and 2 identical at the back..
cant be just 1 different
mdon is offline   Reply With Quote
Old 04-10-2010, 08:28 PM   #9
JustMadeTheCut
My Ride: bmw-yamaha
i would have them checked for balance like said above. if it happend right after you switched to summers, dont you think something is horribly wrong with those tires?? its just gonna fvck your alignment up the longer you wait. go get them checked out at a tire place and they'll tell you whats wrong. there was another dude with similar problems a little while back. his problem was a bent rim.. but i doubt it with your 17''
Originally Posted by dmon_101 View Post
anything with the word "berry" in it has to be edible
JustMadeTheCut is offline   Reply With Quote
Old 04-14-2010, 11:09 PM   #10
nightowl2k2
My Ride: '03 330i 6MT, '01 M5
How long after installing the suspension did you have the car aligned? When I installed my new suspension (same as your set up) I had the car aligned a few days after. From there I had to have the car re-aligned again after about a month. This is due to the suspension settling which messes up the alignment.
nightowl2k2 is offline   Reply With Quote
