Old 04-11-2010, 08:05 PM   #1
Alaric
My Ride: 05 330CI ZHP
Side Mirrors
I've been having something weird growing within my side mirrors. The thing is, I can't even wipe/scrub this off the mirrors....it's as if, it's happening behind the glass yet protruding through. Very weird.
I've attached some pictures for everyone's reference. Anyone know how to clean this up?
Thanks in advance guys.
ID:	355777   Click image for larger version
Alaric is offline   Reply With Quote
Old 04-11-2010, 08:08 PM   #2
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
Send a message via AIM to B
new glass is only solution I believe
B is offline   Reply With Quote
Old 04-11-2010, 08:48 PM   #3
LittleChrist12
My Ride: 2003 BMW 325xi
This happened to one of my side mirrors once. Water creeps up between the glass and the metal part of the mirror, which rusts. Once it starts, you can't stop it. My spot was far worse and NYS told me it wouldn't pass inspection. Find one from a donor and change it out.
2003 BMW 325xi
2010 BMW M3 Sedan
LittleChrist12 is offline   Reply With Quote
Old 04-12-2010, 06:13 AM   #4
wicked_tattoo
My Ride: 03 ZHP!!!
How hard was this to change out? Or did you change the whole assy.?
wicked_tattoo is offline   Reply With Quote
Old 04-12-2010, 07:34 AM   #5
B
B's Avatar
pop off existing glass... press in to snap on new glass
2 min job
Old 04-12-2010, 08:49 AM   #6
wicked_tattoo
My Ride: 03 ZHP!!!
Do you have any suggestions on where to get the new glass?
Old 04-12-2010, 11:25 AM   #7
B
B's Avatar
I would check classifieds here or on bimmerforums first
then I would shop at www.ecstuning.com or www.getbmwparts.com
good luck!
Old 05-05-2010, 02:18 PM   #8
Zakko
My Ride: 1999 323i
I've got the same problem. I've got heated mirrors, but I see at Autozone I can just get the replacement glass for under $20 + cost of adhesive. They only list the passenger side though, not sure if I can get the driver side as well (which is also bad in my case).
Link for 1999 323i, http://bit.ly/9tlUTp
Zakko is offline   Reply With Quote
Old 05-07-2010, 10:30 AM   #9
Zakko
My Ride: 1999 323i
Part came in today. Perfect match for size and shape.
I managed to get my old mirror off by separating it from the heating element with a small putty knife. The brown stains are where the glass has separated from the metal behind it. I was able to work the knife between the two and not touch the element too much.
I got some 3m water/heat resistant adhesive that I'm going to use to attach it to the frame. I'll post pics when it's done later tonight.
Still need to find a driver's side mirror...
