Sponsored by The Tire Rack
Old 04-12-2010, 02:18 PM   #1
323tom
My Ride: 2 turbo e46's
Bought new tires, need suggestions/help fitting them!
Hey guys, so as some of you know I am doing a m3 s54
swap and hpf stg 2 swap to my non m coupe, anyways I just bought a rear set
of new tires, I went with the Yokohama advan
neova AD08 in 275/30/19... I know these are going to be hard
to fit but I am prepared to make it work, curently my fenders
are rolled and my car is lowered on PSS9s but I plan on raising
it one step back up lol... The rims I have are miro 359 19 x 9.5 rear with 40mm offset, so far I have talked to my body shop about pulling and they don't suggest doing this as the paint could crack which I'm not taking that chance, I could also get rear camber arms
and dial in some negative camber? Also shave the fenders, I also suggested
rolling the fenders more but again my body shop says there's a chance of paint cracking... So I ask for fanatics help?! Has anyone fit 275/30/19 on a non m coupe out there?
Also I have a question about the front tires, I currently have 235/35/19 on 19 x 8.5 offset 35... Is it possible to fit my
current tires that are 245/35/19 on the front? Or will I need camber plates?
Thanks guys!!!
323tom is offline   Reply With Quote
Old 04-12-2010, 02:22 PM   #2
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
You'll definitely have to at least roll your rear fenders. You should be fine in the front though.
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 04-12-2010, 02:36 PM   #3
323tom
Ya
Ya well my rears are already rolled, not completely
flat but there rolled..
Old 04-12-2010, 02:44 PM   #4
Rayce185
Rayce185's Avatar
Let's just say I run 265's with 9.5" width and ET40 (19" BBS CH) in the rear. Even after rolling I can't put two people in the back seats.
dun dun duuuunnnn
Old 04-12-2010, 07:15 PM   #5
323tom
Passengers
Ya i don't plan on ever having passengers, if I didn't have imola red seats I would rip the rear seats out just so I have a excuse to only drive with one other person max haha
Old 04-13-2010, 11:34 AM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
9.5 +40 with 275 AD08's is definitely an extremely hard combo to achieve with out negative camber... You'll probably need at least -2 degrees of camber to see any kind of result in clearance. AD08's run extremely wide and the +40 is already aggressive on a Non-M Coupe.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-13-2010, 12:42 PM   #7
323tom
Cambrr
Ya for sure, what camber arms would you suggest
getting? Thanks!
Old 04-13-2010, 11:36 PM   #8
328DTM
My Ride: LSB //M3
What happened to Toyo R888's?
If you're looking for rear adjustable control arms, you can look into Eibach, Turner Motorsport, Rogue Engineering or UUC. I think KMAC (Ksport?) makes one too, but not sure how the quality is like.
328DTM is offline   Reply With Quote
Old 04-14-2010, 02:50 AM   #9
Midnight Run
My Ride: 05 E46 M3 ZCP
SPC also makes camber arms for E46 as well.
05 E46 M3 ZCP
TCKline Coilovers
SPC LCA camber kit
Macht Schnell wheel spacers
Macht Schnell comp. studs conversion
ADVAN RZ-DF 19x9.0 +22 / 19x10 +22
Midnight Run is offline   Reply With Quote
Old 04-14-2010, 09:29 AM   #10
323tom
Toyo
Ya I am still gertin the r888 once I get a set of the apex arc-8 rims, these tires are my street setup... I will be ordering the turner ones or uuc, the turner are lightwheigt aluminum as the uuc are steel, which ones would be better?
Old 04-14-2010, 05:02 PM   #11
323tom
Wow
So I picked up the tires today and wow they are huge! I really am going to have a tuff time fittig these, can u say -3
camber? I ended up going with the turner motorsports rear camber arms... There on back order For 2 weeks so I'll keep u guys posted once i test fit! With the -3 camber what should the toe be set to?
Old 04-15-2010, 11:40 AM   #12
VMRWheels
VMRWheels's Avatar
If you think the AD08's are wide, R888's are even wider... they run very beefy. Since you are going with such aggressive camber, you may want to check with the guys in the Road Race section for toe recommendations for better steering and grip levels.
-Charles@VMRWheels
Old 04-15-2010, 06:05 PM   #13
323tom
Haha
haha Ya for sure the r888 are definately wider, there also a different class of tire you wouldn't want to use them on the street.. Sounds good I'll post in that section and see if someone can help me out, I was told by someone that the toe should be set to 0 if u have -3 camber but he's also a civic *****
so I don't know if I can trust his word lol...
Old 04-15-2010, 07:22 PM   #14
VMRWheels
VMRWheels's Avatar
Funny thing, my race car is actually a Civic. Currently running Toyo R1R's on it with -2.5 camber up front 1/16th toe out and -2.0 rear with 0 toe. But these settings will be totally differently for a RWD car.
-Charles@VMRWheels
Old 04-15-2010, 10:22 PM   #15
323tom
Haha
Ya my dd is a 2000 civic coupe, very solid car but I don't even come close to trying to mod it haha, but ya I'm sure fwd and
rwd settings are alot differnt, I will post a thread in the race
section tommorow most likely, thanks for your advice!
