Sponsored by The Tire Rack
Old 04-12-2010, 09:24 PM   #1
DriveThruRecFan
My Ride: 1999 BMW 328i
Exclamation Need some help 16x7 et20
I need some help with figuring this out. Ive tried searching up and down.
I have BMW style 29, 16x7 et20, currently they still have the stock tires from an E39 5-series (225/55/16). Right now they rub in the front and rear. If i reduce the size to the std e46 tire size (205/55/16) would this minimize or stop rubbing on all corners?
The car is a 99 328i Sedan. THANKS!
Heres a pic with them on it right now.
DriveThruRecFan is offline   Reply With Quote
Old 04-13-2010, 12:39 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Yes, going to a 205/55 will definitely help out a lot. The sidewall height will decrease and lower the chances of rubbing during compression. Though the offset is still off for an E46, you can get away with it...
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-13-2010, 01:19 PM   #3
DriveThruRecFan
What width would make the sidewall flush with a 16x7 rim?
Old 04-13-2010, 05:30 PM   #4
VMRWheels
VMRWheels's Avatar
205 is a perfect width for a 7" wheel.
-Charles@VMRWheels
Old 04-13-2010, 06:38 PM   #5
DriveThruRecFan
Thanks for all your help, You're awesome!
Old 04-14-2010, 08:20 AM   #6
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Those 5 series wheel are also not hub centric to your car, so you may get some vibration problems at highway speeds.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 04-14-2010, 04:41 PM   #7
DriveThruRecFan
I bought the hubcentric rings.
Old 03-12-2015, 05:43 AM   #8
e46_pt
My Ride: e46
Anyone got 16x7 et20 with 225/50r16?
e46_pt is offline   Reply With Quote
