Old 04-13-2010, 07:26 PM   #1
OuYang.Jai
My Ride: '00 323i Sedan
Send a message via MSN to OuYang.Jai
weird sound coming from engine bay when in idle
When the car is at idle at a red light it will suddenly make a sound like someones spinning the wheel of fortune. Does anyone know what's wrong with it?
Its not just a car. Its a BMW
OuYang.Jai is offline   Reply With Quote
Old 04-13-2010, 07:45 PM   #2
sharky33OCi
My Ride: e92 m3
maybe ur getting the fortune.. no but it could the idler pulley
sharky33OCi is offline   Reply With Quote
Old 04-14-2010, 05:48 AM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Get a hose and stick one end in ear, the other carefully around the pulleys or around engine bay until you find your sound.
Careful around pulleys and belts and fan! My preference for this cheap stethoscope is a 1" flexible electric conduit around 4' long.
Will help you zero in on exact component unless it's buried where you can't get hose to.
HTH
Doug
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 04-14-2010, 09:45 AM   #4
rowdy lee
My Ride: 2000 323ci
either...
Does it sound like, "a can of marbles"?
Possibly (I can't recall...) the DISA unit which has a flap which can break/rivet come loose or something and rattle. Located beside intake manifold.
I'd buy it in a heartbeat... if only I wasn't living on the moon!
rowdy lee is offline   Reply With Quote
Old 04-14-2010, 01:45 PM   #5
OuYang.Jai
It sounds like something broke and like a broken flap keeps hitting a fan. I have no clue what is it. this car has given me so much trouble lately ><
Old 04-14-2010, 02:01 PM   #6
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
AC on or off?
-Gary
DiscoStu is offline   Reply With Quote
Old 04-14-2010, 02:17 PM   #7
dmax
dmax's Avatar
Idler pulley is a good guess...but stick hose around to each of the pulley and you'll hear a distinct difference and be able to isolate it.
Check water pump, and make sure your fan isn't just hitting a stick that got caught in the fan shroud...make sure car is off and fan is off! Or remove--if manual, 3 mins., if auto, 5 mins. with proper tool...seemingly 50/50 without this magic tool...not familiar with it, but understand the theory.
Anyway, good flashlight, lots of looking...moving hose around...you'll find thing...then get picture from searching or taking and someone will know what part has failed.
Doug
dmax on Facebook
Mangofy your E46!
Old 04-14-2010, 02:52 PM   #8
cabl3i
My Ride: 03 330i ZHP
Is the sound consistent? My car makes this exact sound at idle, but only during cold starts...and even then it only happens on about 3/5 cold starts..very strange because the sound goes away after like 15 seconds.
If your sound is constant I'd say you're lucky in the sense that you at least have time to figure out where the sound is coming from...I only get 15 or 20 seconds IF the sound comes on during a cold start.
Its starting to bug the hell out of me as I want to fix it before it becomes a bigger problem.
cabl3i is offline   Reply With Quote
Old 04-14-2010, 03:28 PM   #9
cabl3i
If you can, post up a video so we can know more or less exactly what it sounds like.
Somehow, our engines manage to produce a number of different "knocking" or "rattling" noises.
Old 04-15-2010, 04:27 PM   #10
cabl3i
Im gonna go out on a limb here, but I'd bet if you turn your A/C off, the noise will stop.
I've realized when my wheel of fortune turns on during cold starts, it immediately goes away if I turn A/C off.
So what conclusions could we draw from that?
Old 04-16-2010, 05:57 AM   #11
OuYang.Jai
AC is OFF.
i will post a video of the sound tomorrow when i get a chance.
Also, this happens 9/10 times when i come to a full stop at a red light
Old 04-16-2010, 09:30 AM   #12
cabl3i
Actually, I went in my car this morning, turned ac off and started the engine...wheel of fortune still came on.
I'm gonna spend all saturday tryin to find out what it is...I hope its something easy like a tensioner or idler pulley.
Will wait for your video...here's a thread I had started previously with some videos for your reference:
http://forum.e46fanatics.com/showthr...717&highlight=
Old 04-16-2010, 05:37 PM   #13
usc_hennessy
My Ride: e46....duh....
I have the SAME problem!!! - just started recently, but def with the cold starts and only stays for a little bit and comes back on and off at red lights. Drives me crazy!
usc_hennessy is offline   Reply With Quote
Old 04-16-2010, 05:51 PM   #14
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Remove the belts if the noise is still there(DO NOT RUN THE CAR LONG WITH BELTS OFF) then remove and check the DISA valve
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 04-28-2010, 11:36 AM   #15
cabl3i
Can the Disa valve really become that loud?
Old 04-28-2010, 12:34 PM   #16
jbeurotech
Regional Sponsor
can the disa valve really become that loud?
yes
Seth Thorson
Old 04-28-2010, 01:10 PM   #17
rowdy lee
My Ride: 2000 323ci
another sound...
on a cold start, the injection? air pump runs for a period of time and shuts off. It's round, black top and over by-behind- the washer fluid tank. There is also a small vacuum hose with this unit which can rot/dry out... also, is it a vacuum valve there? can have problems rarely.
Removing belts for +/- :30 to :45 seconds is a good idea...
Old 04-28-2010, 02:21 PM   #18
cabl3i
I figured as much it would have something to do with the secondary air pump (that black circular thing you described next to the washer fluid tank). Will check it out as well.
So you remove the belts and then start the car and let it run for give or take half a minute?
Old 04-28-2010, 02:40 PM   #19
rowdy lee
My Ride: 2000 323ci
well...
You have to realize that the only "cooling" will be from the absorbtion of combustion heat into the engine metals and the water left in the cooling passages. The water pump won't be turning, moving coolant past hot spots and etc. and the thermostat will be closed.
Start from a cold engine rather than hot.
Don't run for more than 30-45 seconds.... If I had to do it on mine, I would, being very cautious.
A Chevy 327 with iron heads can take a trip around the block without any coolant... but a BMW?
Anyone else?
Old 04-28-2010, 03:16 PM   #20
cabl3i
Right of course, it'd be completely ridiculous to leave it on for an extended period of time.
I've had my run-ins with BMW cooling systems in the past, so I know on what kind of balance they run.
Thanks for the heads up though.
