Sponsored by The Tire Rack
Old 04-16-2010, 12:16 AM   #1
theSYNDICATE
My Ride: Steel Grey E46
Spacer question
I just got some Type C's for my E46 M, they are in a square fitment so I want to run some spacers in the rear to make them a lil more flush in the back.
They are 18x9.5 all around +38, I'm thinking 10mm spacers which would in theory lower it to +28 in the rear.
I'm thinking the ecs kit with bolts. Is there a better/safer kit, I still have worries about running spacers because of stories I've heard(fairy tale or not).
Thanks for any help.
theSYNDICATE is offline   Reply With Quote
Old 04-16-2010, 01:48 AM   #2
Snik
Snik's Avatar
My Ride: IR M3 Vert.
As long as the spacers are machined from a solid billet piece, you shuld be fine there. The more important thing is bolts, proper length. Ie. Not too short. Get a hubcentric spacers, makes for less chance of error when mounting the wheel, and keeps it concentric. If it isn't, the car will ride like its on woodern wimz. And I'd go with a wider spacer on thos rears, since the rim is so narrow. I'd suggest 15mm spacers out back.
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 04-16-2010, 11:34 AM   #3
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
You can run up to a 15mm spacer safely without having any kind of rubbing issues on a 275 tire in the rear.
Spacers are perfectly fine as long as you run a high quality spacer kit with proper length lug bolts. ECS, Rouge, Mach Schnell, H&R all make high quality spacers with proper length hardware included.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-16-2010, 12:27 PM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Stick with a quality brand that is hub centric. H&R TRACK+ Spacers will do just that.
Old 04-19-2010, 01:17 AM   #5
theSYNDICATE
Thanks, I'll go with 15's out back then. I want it to be as flush as possible.
