Sponsored by The Tire Rack
Old 04-16-2010, 04:04 AM   #1
Penn
My Ride: RS4
Spacer size question.
Ok, so I asked the same question in my showroom thread, but I figured I'd get faster answer here.
What size of spacer should I run in front? Wheel specs are: 225/40-18 Offset: 40mm.
Right now I have +5mm, but I'd like it to be more flush with out hardcore rubbing (already rubbing in the back, haha). Anyways I was thinking switching to either +10 or +12.
Any suggestions?
Penn is offline   Reply With Quote
Old 04-16-2010, 04:09 AM   #2
Snik
Snik's Avatar
My Ride: IR M3 Vert.
So what's the wheel width? 10s look like they'll work fine with that setup. If they're 18x8s I'd prolly try some 15mm ones on there. If they're 8.5 then I'd stick to 10 or 12 to avoid possible rubbing depending on suspension setup.
Do you ride a sportbike?
Old 04-16-2010, 04:10 AM   #3
Snik
Snik's Avatar
Btw, how the hell did u get that color. Custom paint, or special order?
Old 04-16-2010, 04:33 AM   #4
Penn
My Ride: RS4
I believe they are 18x8. BTW I'm also dropped (HKS coils). The thing is I need to order them so I really can't try what fits best =/
It's a special order. Not many non-m coupes with that exact paint around, if any. Haven't seen one yet.
Old 04-16-2010, 04:48 AM   #5
Snik
Snik's Avatar
Well, if they're 8" wide, I'd go with 15mm, if they're 8.5" wide I'd go with 10 or 12mm. It al depends on how much poke you want.
Old 04-16-2010, 12:37 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
To avoid any kind of issues with rubbing, measuring the spacer on your own may be a better idea. Each cars alignment and and tire manufacturer are different, so one fitment that works for a person may not work for another.
Just pull out a tape measure and check the gap between the tire shoulder and fender.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
