Old 04-16-2010, 05:16 PM   #1
323tom
My Ride: 2 turbo e46's
Negative camber/toe question
Hey guys, so I decided to order a set of 275/30/19 Yokohama Advan AD08 tires, if I had a m3 I would only need to roll my fenders to fit these... Anyways I have a non-m coupe and I need to fit these on the car... I ordered a set of turner motorsports adjustable rear control arms... I plan to set the camber at -3, I will be driving it on the streets more then track obviously and I am aware the tires will wear out uneven but I will only be driving the car 2-3 times a week... what should the toe be set to with -3 camber?
323tom is offline   Reply With Quote
Old 04-16-2010, 07:30 PM   #2
vaio76109
My Ride: Race Cars
I assume we're just talking about rear here, ~1/8" toe in.
vaio76109 is offline   Reply With Quote
Old 04-16-2010, 07:35 PM   #3
ChasCan
My Ride: 2001 330xi
Toe should be set at factory spec, however -3 deg camber is way too much for street driving. Should be set at -1deg or at the most -1.5 deg for the street. Chas
ChasCan is offline   Reply With Quote
Old 04-16-2010, 09:17 PM   #4
FTWeisse
My Ride: has no hip-hop rimz
If you're running on street, then try to get the MOST positive camber out of them as possible without rubbing.
Lots of guys running 19" CSL reps with 265s get away with -1.8 without rubbing. I recon about -2 should do it for you...
Normally I'd agree with Vaio about the toe, but since you're on street, just go 1/16 - tops.
$.02
Old 04-17-2010, 12:05 PM   #5
323tom
thx
thx for the replies guys! so I guess 1/16" at -2 camber is what im going to try... whats the factory toe settings? are csl reps 19x9.5 or x10?
Old 04-17-2010, 02:05 PM   #6
FTWeisse
I don't remember what the OEM toe specs are. I believe the CSL Reps are 9.5". Now, keep in mind that the tire you run has an effect on how far the sidewall protrudes - some sidewalls are more round than others and therefore stick out less. -2 is a number I came up with by deductive reasoning, but its not a guarantee that you won't rub. Talk to your tech when you get to the shop and ask him to keep the rubbing issue in mind - he should be able to eyeball whether a certain setting will work or not. Just ask him to dial in as much positive camber as possible without the tire rubbing the fender.
Just a heads up...
