Old 04-18-2010, 06:37 PM   #1
fourwhls
My Ride: 323ci
Possible to automatically turn off DSC?
Is there any way possible to automatically turn off DSC when you start the car?
There is a company making a circuit board that allows Mini owners to do just this. They call it "Track mode DSC". Here's a link: http://www.waymotorworks.com/auto-up...2-06-mini.html
Is it possible to do this on an e46?
I made the mistake of not turning off DSC during my final run at the autocross today. It cost me my last run.
I will probably never make this mistake again, but nonetheless, it pissed me off.
Shawn
"If everything seems under control, you're just not going fast enough."
Mario Andretti
fourwhls is offline   Reply With Quote
Old 04-18-2010, 07:12 PM   #2
SDKmann
My Ride: 01 Cherokee
That is really cool, pretty cheap too. I wonder if there is also a way to turn it back on if you feel you need it when driving.
SDKmann is offline   Reply With Quote
Old 04-18-2010, 08:31 PM   #3
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
You can build a circuit using the 555 timer, cap and a resistor. That will work. Basically, when the car starts, close the circuit for 3s. Then open it.
t=1.1*R*C IIRC. Hopefully not too rusty! So from there decide what R and C you need.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 04-18-2010, 09:43 PM   #4
SDKmann
That is about how far I got before I had absolutely no understanding of what you said.
Old 04-19-2010, 01:27 PM   #5
Kubica
My Ride: 2003 325xi
Could just disconnect a wheel speed sensor, which will also disable ABS. No?
Old 04-19-2010, 01:38 PM   #6
uninc4709
My Ride: 2002 BMW 325i 5spd
pretty cool concept. would be nice for an e46 maybe with a few more features
^^ more than likely a useless post
uninc4709 is offline   Reply With Quote
Old 04-20-2010, 02:41 PM   #7
e46techtuner
My Ride: 2000 328i
just make a check list and tape it to your dash.
my reads as follows:
-Harness
-Helmet
-Balls
-DSC off
e46techtuner is offline   Reply With Quote
Old 04-20-2010, 08:06 PM   #8
vaio76109
My Ride: Race Cars
Unplug the DSC accelerometer under your seat(under the carpet).
vaio76109 is offline   Reply With Quote
Old 04-20-2010, 10:44 PM   #9
SC_TR0JAN_M3
My Ride: 2004 BMW M3
is it really that hard to remember to turn it off?
SC_TR0JAN_M3 is offline   Reply With Quote
Old 04-20-2010, 10:46 PM   #10
lllSupra
My Ride: E46 330i
seriously just hold the button down until the 2 yellow lights pop up... I do it 90% of the time when I drive
lllSupra is offline   Reply With Quote
Old 04-22-2010, 12:03 PM   #11
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
If you search Andy Sapp, he has a thread explaining how he did it in his 325 drift car.
found it.
http://forum.e46fanatics.com/showthr...630&highlight=
it turns off dsc, but also abs. lol
SL Blak Soldier is offline   Reply With Quote
Old 04-22-2010, 12:09 PM   #12
QwikFlip
My Ride: 04' 330ci and 02' M3
Not sure, but I think the conforti shark software can be custom programmed with different options regarding DSC. Might only be for M3 though. Worth looking into though if it really bothers you.
IForged Monaco (19"), Bilstein PSS9's, Conforti CAI, Dinan Stage 2 Software, Racing Dynamics Strut Tower Brace, 3.23 Diff, UUC Sway Barbarians, Wilwood BBK, UUC Pulleys, UUC TS3 Exhaust
QwikFlip is offline   Reply With Quote
Old 04-22-2010, 03:46 PM   #13
Kubica
My Ride: 2003 325xi
found it.
Like I said . . .pull a wheel speed sensor!
Old 04-24-2010, 02:48 PM   #14
murph1379
My Ride: 2006 M3
My mechanic claims that he can program autologic software to do this. It's quite a bit more than the shark injector, so I went that way instead.
I say that every time I do it! lol
murph1379 is offline   Reply With Quote
Old 04-24-2010, 03:18 PM   #15
jdmrrs
My Ride: E46 M3
Where do you unplug the Passenger Side, Rear Speed Sensor?
jdmrrs is offline   Reply With Quote
Old 04-24-2010, 04:09 PM   #16
FTWeisse
My Ride: has no hip-hop rimz
Just don't forget to turn it off - that way you can keep your DCS for when you really need it
Old 04-25-2010, 05:30 PM   #17
Kubica
My Ride: 2003 325xi
I have an xi, but I'm assuming there's a little black plastic box in the wheel-well where you could easily disconnect it. Just follow the sensor wire . . .
Old 04-25-2010, 05:36 PM   #18
ChasCan
My Ride: 2001 330xi
Sorry. Just don't quite get it, but why do you want your DSC off especially when tracking?? Chas
ChasCan is offline   Reply With Quote
Old 04-25-2010, 05:47 PM   #19
Messe46
My Ride: 325xi ZSP - ONRLS
Send a message via AIM to Messe46
the program gets in the way of controlling your car the way you need it on a track. for instance if you know that a little bit more throttle would correct a little under-steer, but the dsc is on... you'll continue to under-steer because the program will not allow over-steer. hope that helps.
-Mike
Im sorry, but having an Aston Martin DB9 on the drive and not driving it is a bit like having Keira Knightley in your bed and sleeping on the couch. If youve got even half a scrotum its not going to happen.
-Jeremy Clarkson
Messe46 is offline   Reply With Quote
Old 04-25-2010, 05:54 PM   #20
ChasCan
My Ride: 2001 330xi
Ah! now I get it. Thanks. Chas
