Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 04-07-2003, 05:51 PM   #1
JByron
JByron's Avatar
My Ride: Two-wheeled unicycle
Wattage Inquiry
so i'm planning on buying the alpine cda-9815, but here's the thing:
the 9815 puts out 60Wx4, whereas my amp puts out 50Wx4. should I even bother with the amp then?
if i still decide to run the amp, is there an internal amp muting circuit in the 9815?
So-Cal Sig Size Compliance Society: Now Less Than 800 pixels!
JByron is offline   Reply With Quote
Old 04-07-2003, 06:02 PM   #2
spoiled808177
My Ride: 2003 325i
even though the deck says it will produce 60x4 in almost every single case will not produce the 60x4. From what i know it would produce somewhere like 23-27 watts. 60x4 mean that the deck can push it for maybe a half second where it doesn't even do anything. if i was u i would get the amp. i will sound much better.
im not sure what u are refering to when u say internal mounting circuit.
spoiled808177 is offline   Reply With Quote
Old 04-07-2003, 06:40 PM   #3
JByron
JByron's Avatar
internal amp MUTING circuit. is there a feature to turn off the internal amp completely to improve the signal going to the amp? a lot of HUs tout it as a feature but i can't find it in an 9815 literature
Old 04-08-2003, 12:50 PM   #4
Tesh323
My Ride: Mini CooperS
My Alpine CDA 7893 has a POWER IC OFF function to turn the internal amp off, this makes more current available for the head unit to drive the pre-amp circuits and hence the output down the RCA leads to the amps is better. Final result is better sound quality!!!
Tesh323 is offline   Reply With Quote
