Old 04-20-2010, 07:41 AM   #1
James330I
Imported Redneck
My Ride: BMW baby 330i 5spd
Send a message via AIM to James330I
brake pad install difficulty on '01 330i and sensors
hey guys,
brake light came on so I need to order me some front and rear pads for my 01 330i.
Got a couple of questions
* The DIY for brake pad install seems easy. Is it really that simple? Any tips? I've done work on my car before (window regulators, A/C motor resistor: pretty simple stuff)
* Can I not re-use brake pad sensors? Do I have to buy new ones??
TIA
2001 Dinan 330I 5spd (gone..what an awesome car)
2013 335i 6spd M-sport
2013 Infiniti M37S
James330I is offline   Reply With Quote
Old 04-20-2010, 07:55 AM   #2
paraklas
My Ride: ESS TS2 320ci
If brake light comes on = new sensor required.
and it's very easy
Old 04-20-2010, 07:59 AM   #3
BimmerFerret
My Ride: 08 G37S, 07 Sky RL
I think you can actually re-use the sensors as long as you don't break (no pun intended) them! I believe the sensor trips only when the pad wears down to a certain point.
IMO, brake jobs are one of the simplest jobs to do and one of the biggest jobs shops overcharge on. Just my opinion. If you don't take the calipers off of the brake line when you change pads, you don't have the bleed the brakes, which makes your life way easier. There is a great YouTube video where a guy shows a step-by-step process of changing pads on an E46.
Here you go... Happy 4/20.
2008 Infiniti G37S - Big Brakes, Limited Slip, etc.
2007 Sky Redline
1998 Honda Civic EX Sedan
Originally Posted by Roxlo View Post
Class of '03, yet you're still an idiot. Whats your point? Do you really think that you're somehow a god because you joined a site before someone else? ****ing nerd.
BimmerFerret is offline   Reply With Quote
Old 04-20-2010, 08:03 AM   #4
James330I
Imported Redneck
I appreciate it guys. Thanks!
2013 Infiniti M37S
Old 04-20-2010, 08:06 AM   #5
gte869h
My Ride: 2002 330i Orient Blu
Yeah, if your sensor has worn to the point of tripping the light inside you can re-use it no problem. And brakes are one of the easiest DIYs, just make sure you clean the friction surfaces from any dirt/grease/oils from your skin. And lubricate the caliper slides with caliper grease.
gte869h is offline   Reply With Quote
Old 04-20-2010, 11:12 PM   #6
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
that is a cool video!
thanks.
delmarco is offline   Reply With Quote
Old 04-20-2010, 11:26 PM   #7
WALKD U
My Ride: Just Fast!
Originally Posted by James330I View Post
hey guys,
TIA
TIA,
1. Yes it really that simple. I would rate it 3/10 If u can do those stuff u have listed. This should be no problem. Just take your time and enjoy learning
2. Yes, you can re-use the Brake Pad Wear Sensor if they have not been tripped. Or you can just replace them for the peace of mind.
If you have any more question...You know what to do
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 04-21-2010, 12:21 AM   #8
nsimo7050
My Ride: 2001 330Ci
I did my front and rear today. It really is that easy>
nsimo7050 is offline   Reply With Quote
