Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 09-24-2011, 03:55 PM   #181
TrippinBimmer
My Ride: Just Fast!
Originally Posted by TxZHP04 View Post
Got the S54 tensioner in this morning. Working around the A/C lines proved to be a bit tricky but I finally managed. Also, it does take a bit of force to compress the tensioner enough to get the threads to catch and this made me very paranoid about the possibility of cross-threading it. I didn't have any problems but I figured it was worth a reminder to folks to be careful. Once the threads catch, you should be able to easily thread the cylinder in the rest of the way by hand even though it's under tension. If it doesn't thread in freely, back it out and start over.
The engine made nothing but good noises this morning on a cold start after the tensioner install. I didn't notice any of the timing chain "ringing" that I've noticed since the exhaust cam upgrade. Haven't been out driving yet though so remains to be seen if I notice and other difference.
Time for me to upgrade as I do get that ringing noise when I do a cold crank. So annoying.
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 09-29-2011, 01:26 PM   #182
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Got my tensioner today. Hopefully I can put it on tonight.
Old 09-30-2011, 08:27 AM   #183
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
At idle, I get a noise from the front of the engine, something between a rattle and grind. I've been told that the chain in the VANOS becomes loose and drags along the chain guide. I've done the Besian upgrade and then got a new unit from Dr. VANOS.
Never had a noise until I swapped in the FI cams and installed the S/C kit.
So could this noise be my chain tensioner?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 09-30-2011, 09:12 AM   #184
aggieE46
Keep it clean
aggieE46's Avatar
I still had a little noise after doing my Beisan seals and the rattle fix. ATI damper brought the noise down a little, and the new tensioner last night took things down another level.
Old 09-30-2011, 10:00 AM   #185
TxZHP04
My Ride: ESS TS2+ ZHP
At idle, I get a noise from the front of the engine, something between a rattle and grind.... Never had a noise until I swapped in the FI cams and installed the S/C kit.
Kind of a coarse rumble? Could it be the SC'er itself? I know my Lysholm TS always made an annoying bit of clatter at the stock idle speed. I had Asbjorn bump my idle speed up to about 900 rpm somewhere along the way and it pretty much eliminated the noise. If we meet up next time you're up this way, I can take a listen and see if your noise sounds the same. Posting up an under hood video might work too.
Old 09-30-2011, 10:08 AM   #186
aggieE46
Keep it clean
aggieE46's Avatar
Oh, my notes on installing the damper.
Due to the AC lines that were already pointed out, your best bet is using the 32mm socket with a 3/8 to 1/2 inch adapter and a 3/8 ratchet. Also note that the "nut" end of the tensioner is longer. The socket that I used to take my stock one off wasn't deep enough to torque down the new one. I had to take the Xterra to Autozone and rent a 32mm axle socket for 5 minutes. Other than that, pretty easy. Just have to have some patience starting the threading like Darren said.
Old 09-30-2011, 10:59 AM   #187
bigjae1976
bigjae1976's Avatar
Yes...kind of speeds up as the revs go up to about 2k rpm and then goes away.
I'll call AA to check into that.
Old 09-30-2011, 12:27 PM   #188
TxZHP04
Don't think I've ever noticed the compressor noise over 900-1000 rpm on my car but you do have a slightly different compressor as well as a CAI (whereas I still have the stock air box). I suppose you could always let the car idle for a very short period with the belt off to see if the noise goes away.
Old 09-30-2011, 03:05 PM   #189
aggieE46
Keep it clean
aggieE46's Avatar
He has a UUC flywheel, too. Idle bump helped me out a lot with that.
Old 09-30-2011, 03:54 PM   #190
TxZHP04
How's your gear rattle with the increased idle speed plus the ATI damper? Could you tell any difference with the damper?
Old 09-30-2011, 04:10 PM   #191
aggieE46
Keep it clean
aggieE46's Avatar
Rattle was gone with the bumped idle. Installed the damper after the software. Sorry
Old 10-01-2011, 12:00 AM   #192
bigjae1976
bigjae1976's Avatar
I think I'll just do the tensioner and call it the day. If it still rattles, oh well. My car has been running fine for over 40k already...
Old 10-14-2011, 05:56 PM   #193
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
So, while I was working under the hood swapping the PS stuff AGAIN... I inspected the HB and it does have a little of the gasket showing. Further, I installed the tensioner on the wagon, only took about 10 minutes.
I still need to install the Dinan TB on the wagon, I have had one on the sedan for a few years.
Old 10-24-2011, 07:37 PM   #194
MasterC17
My Ride: hates A/C & Sunroofs
Ok, I'm ready to order one of these. Is there ANY interest in a Group Buy Round Two? Also, it's not listed on ATI's website, so I guess I should just call them and tell them what I need?
MasterC17 is offline   Reply With Quote
Old 10-25-2011, 07:30 AM   #195
SoloII///M
My Ride: Many
I'm interested in one. If there was another group buy, I would be in. We're planning to run our DSP car to around 7 grand and I'm not in the mood to be tearing down motors.
Can someone please clarify whether the install tool is available or whether we have to fab our own?
SoloII///M is online now   Reply With Quote
Old 10-25-2011, 11:56 AM   #196
aggieE46
Keep it clean
aggieE46's Avatar
The group buy took over a year to complete. You might just want to save your pennies and order it individually. We're not going to put Anthony through that hell again. ATI was pretty difficult. I doubt many forum sponsors would help like he did. He was just supposed to be a money handler for it and ended up losing money on the deal. Not cool.
Old 10-25-2011, 07:54 PM   #197
Jackcat559
My Ride: 2003 530
ATI is literally 20 mins from Columbia, MD. I went directly to them to get mine. With the measurements they need for the order, and not being race season, you could be able to get it relatively quickly.
If you do I'll even help put it on, and I have the special tools. I live up bu UMBC
Jackcat559 is offline   Reply With Quote
Old 10-26-2011, 05:38 AM   #198
SoloII///M
My Ride: Many
Thanks and thanks - I would definitely provide beer for help with that.
I'll contact them and see what they can do.
Old 11-30-2011, 11:33 PM   #199
TrippinBimmer
My Ride: Just Fast!
how everyone tensioners doing?
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 12-01-2011, 06:51 AM   #200
330i ZHP
330i ZHP's Avatar
so far no problems - not sure if i notice a difference
