Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#161 |
The diameter of the inlet and outlet oil holes is different.
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things |
#162 | |
#163 |
I just found out that the E83 X3 3.0i has the same M54B30 engine but that it uses a different HB.
X3 - 11237513862 ![]() ![]() 330 - 11231438995 ![]() Different part numbers. I'm not sure if they have differences. Any thoughts?
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things Last edited by new//M3fan; 09-12-2011 at 11:34 AM. |
#164 |
Doesn't appear to be unique to the X3. Courtesy realoem:
Part Cross-reference RealOEM.com Home Part 11237513862 (Vibration damper) was found on the following vehicles: E39: Details on E39 E39 525i Touring E39 525i Sedan E39 530i Sedan E46: Details on E46 E46 320i Sedan E46 325Ci Coupe E46 325Ci Convertible E46 325i Sedan E46 325i Touring E46 325xi Touring E46 325xi Sedan E46 330Ci Convertible E46 330Ci Coupe E46 330i Sedan E46 330xi Sedan E53: Details on E53 E53 X5 3.0i SUV E60: Details on E60 E60 525i Sedan E60 530i Sedan E83: Details on E83 E83 X3 2.5i SUV E83 X3 3.0i SUV E85: Details on E85 E85 Z4 2.5i Roadster E85 Z4 3.0i Roadster
#165 |
tensioner replacement
So is the installation of the S54 tensioner as simple as torquing it to spec? Do the oil holes need to be aligned any particular way? Seems like the inner tensioner piece may spin a bit within the cylinder as it's torqued down so I'm assuming there are no alignment concerns.
BTW, the tensioner I received also has the same sticky point when compressed about 25-30%. I'm starting to think that it's simply an inherent part of the design.
#166 |
So, with an ATI Damper installed what are the chances of the oil pump nut coming off or the oil pump shearing in relation to the stock damper?
#167 |
Perhaps less than stock? At this point you're not likely to get anything more than conjecture as there simply isn't any long term data to prove anything one way or the other. I think that most who have ever run an ATI damper on an M54 have posted in this forum and I don't think any of those same people have ever had any issues with their oil pump with the stock damper (except Adam whose current build is still in progress I believe).
#168 | |
![]() Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs Turbo Driveability Video Horsepower vs. Torque - updated |
#169 |
Hmm, thanks for the responses. The question now is do I run the car until the opn comes off or the oil pump shears, or do I invest in the ATI Damper. I always make sure I shift ~6000 so who knows if it will even come off.
#170 |
If you're shifting at 6k, you're not very likely to ever have oil pump issues. If you're spending significant time hanging out above 6k rpm or making even brief bursts above 7k then you might worry.
Now, before the question gets lost... can someone comment on my tensioner install question above?
#171 | ||
Good luck.
![]() Rob #43 ITS/ITR/STU, BMW 325I, STU LAP RECORD SUMMIT POINT WV 1:24:229 S.C.C.A. http://www.vimeo.com/8486878 (Dyno Video) ........add a sh!tload of cowbell. |
#172 | |
#173 |
Yes, that sounds good. When installing the VAC OP kit, I'd still drill & wire tie the OPN.
Then if it were me, I'd buy a Shark Injector & enjoy 7000 RPM as often as you like. I'm serious.
#174 | |
#175 |
Thanks for the confirmation!
#176 |
Got the S54 tensioner in this morning. Working around the A/C lines proved to be a bit tricky but I finally managed. Also, it does take a bit of force to compress the tensioner enough to get the threads to catch and this made me very paranoid about the possibility of cross-threading it. I didn't have any problems but I figured it was worth a reminder to folks to be careful. Once the threads catch, you should be able to easily thread the cylinder in the rest of the way by hand even though it's under tension. If it doesn't thread in freely, back it out and start over.
The engine made nothing but good noises this morning on a cold start after the tensioner install. I didn't notice any of the timing chain "ringing" that I've noticed since the exhaust cam upgrade. Haven't been out driving yet though so remains to be seen if I notice and other difference.
#177 | |
Very good, very cool.
#178 | |
Keep it clean
Thanks for the review, Darren! It's definitely on my short list.
#179 |
My Ride: have 5 doors and FI
ordering two of the chain tensioners - another $300 down....
![]() /_________\ OO=[][]=OO |
#180 |
Keep it clean
See, that's what you get for having 2
