Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Great Plains & Rocky Mountains
CO IA KS MO MT ND NE SD WY
Thread Tools Search this Thread Rating: Thread Rating: 19 votes, 4.58 average.
Old 10-20-2010, 06:46 AM   #2661
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
Originally Posted by delirium45 View Post
anyone with E46 M3 need a valve adjustment done ?
i just did mine tonight and still have the kit and tools...
obviously don't need it.... but how involved was it? just curious what all needed to be done.
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 10-20-2010, 09:31 AM   #2662
delirium45
My Ride: 2004 M3
1) gain access to crankshaft pulley (to turn cams manually), if you don't have the front of the car off, this means removing the fan clutch and shroud.
2) remove valve cover and spark plugs (so you can turn the engine easier).
3) check gap between cam and rocker when cam is in up position.
4) if gap is out of spec:
4a) remove rocker retaining clip
4b) slide rocker off valve
4c) using special BMW tool retrieve valve shim from out of spec valve spring top
4d) measure shim
4e) determine required shim thickness to bring it back into spec
4f) install new shim of required thickness with special BMW tool
4g) replace rocker, replace retaining clip
4h) re-check gap to ensure it is within spec
... do this for all 24 valves and you should be good.
i'd say that it takes about two hours to disassemble the car to gain access to what you need and then another two hours to be meticulous about shimming. and then another one hour to put everything back together.
this is why BMW charges arm+leg for the job.
_ Garrett
2011 Rocky Mountain Region GTS4 champion & "Rookie of the Year"
2012 Rocky Mountain Region GTS3 champion
Thanks Sponsors: SCR Performance & Built-by-Bones
delirium45 is offline   Reply With Quote
Old 10-20-2010, 02:16 PM   #2663
WhatHappening
My Ride: TL-S
Send a message via AIM to WhatHappening
Anyone interested in a meet/cruise/dinner/photo op? A few guys from acurazine and myself are meeting up to take pictures and cruise. Here's a link if you just want to check it out http://www.acurazine.com/forums/showthread.php?t=795538 but if you want to go just let me know and I could add you guys to the list. My buddy is coming with his M3 and he would definitely love some beamer guys to be there with him.
-Anthony
WhatHappening is offline   Reply With Quote
Old 10-20-2010, 03:58 PM   #2664
docwyte
My Ride: '89 944 Turbo
Anyone going to High Plains Raceway this Saturday? I'll be there with the LS1 944.
'98 M3, track beast
'06 Porsche Cayenne Turbo S 521hp daily driver
'07 KTM 990 Adventure
docwyte is offline   Reply With Quote
Old 10-20-2010, 05:11 PM   #2665
Cazz
My Ride: 2005 BMW M3
I just had mine done 2 weeks ago. It had 12 valves out of spec.
Cazz is offline   Reply With Quote
Old 10-20-2010, 05:48 PM   #2666
delirium45
My Ride: 2004 M3
i had four out and three at the limit on exhaust side, and one out and two at the limit on the intake side... i changed all 10.
_ Garrett
Old 10-20-2010, 08:36 PM   #2667
PEZi720
My Ride: PPIHC Racecars
garrett... come do valve adjustment on sreepy..... i'z lazy
PEZi720 is offline   Reply With Quote
Old 10-21-2010, 12:13 PM   #2668
Dan1983
My Ride: X3 35i, MaxPsi M3
I'm going to need to do a valve adjustment soon.
Dan1983 is offline   Reply With Quote
Old 10-21-2010, 12:31 PM   #2669
delirium45
My Ride: 2004 M3
how soon ?
i'm either looking to recoup some of my investment by doing some local jobs with it, or reselling the kit.
the kit itself is over $400...
_ Garrett
Old 10-21-2010, 12:41 PM   #2670
Dan1983
I'm sure it already needs the adjustment, the lifters are making some noise and I don't know when it was done last. I just need to find time to do it. Probably after I install the power steering pump on my 325i so I have something to drive while I take the M apart. So I guess in the next month or so.
Old 10-21-2010, 12:47 PM   #2671
delirium45
My Ride: 2004 M3
do you want to buy the kit from me, or have me do it for you (for a price) ?
i would sell, as a full kit all the tools needed to do the job (shim kit, shim recovery tool, digital mic, feeler gauges and i'll even throw in the bought-yesterday-used-today tube for high-temp RTV sealant) i can also provide you a list of all of the gaskets you'd need to get in advance to put everything back together.
_ Garrett
Old 10-21-2010, 01:02 PM   #2672
Dan1983
Are you open to renting the kit? I already have a digital micrometer and some feeler gauges.
Old 10-21-2010, 01:05 PM   #2673
delirium45
My Ride: 2004 M3
yes, i'm open to renting it for a smaller fee, however, i'd prefer to rent it sooner than later as i need to cycle some cash back into the 'program' =)
_ Garrett
Old 10-21-2010, 02:09 PM   #2674
HN00
My Ride: 2005 CB M3
i'm also due for a valve adjustment, how much do you charge Garrett?
HN00 is offline   Reply With Quote
Old 10-21-2010, 02:48 PM   #2675
delirium45
My Ride: 2004 M3
sent you PM.
_ Garrett
Old 10-22-2010, 03:09 AM   #2676
02m3csl325
My Ride: is Stage 2 AWD!
Guys please sign this if you havn't already.
http://www.petitiononline.com/coplate/petition.html
02m3csl325 is offline   Reply With Quote
Old 10-22-2010, 10:18 AM   #2677
HN00
My Ride: 2005 CB M3
signed! that would be nice, if it passes.
Old 10-22-2010, 10:36 AM   #2678
5280 M3
My Ride: 2002 M3
Winter driving
Fellas--I'm about to purchase a set of Blizzak LM-60's for the OEM 18" staggered setup on the e46 M3. You all think that'll do fine for winter here in Denver?
5280 M3 is offline   Reply With Quote
Old 10-22-2010, 11:10 AM   #2679
02m3csl325
Yes, Blizzak makes a good tire, these are what I run in the winter.
Old 10-22-2010, 03:37 PM   #2680
PEZi720
done
bmw exberts, colorado, denver, fifi, gaga ooh-la-la, kitty puuuuury, mile hi, more than you can afford, rolf, saint louis!, spee, steven was huuuurrr, steven's a girl eepsspee, toolberts, trebdesumanu, tuuuuuuuuuuuurbo awd?, vtec power
Rate This Thread
