Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Great Plains & Rocky Mountains
CO IA KS MO MT ND NE SD WY
Thread Tools Search this Thread Rating: Thread Rating: 19 votes, 4.58 average.
Old 01-15-2011, 12:53 AM   #3261
cd330
ModZombie Moderator
cd330's Avatar
My Ride: SG E46, AW F30
Originally Posted by PEZi720 View Post
WAT!?!?!?
sadly azfag0r is stuck in malaysia... and as most have realized at this point, none of us live in ACTUAL denver... but around denver
i'm about an hour south if you make it to colorado springs and feel like seeing a random autocross project.... *ahem*.... truck
i'll be in denver tomorrow but not for long before i have to come back and go to work...
Damn! Yes, I am familiar with the area. My mom and brother used to live in the Springs. My mom now lives in CastleRock and my brother lives in Breckenridge.
Well, I will be there for a week so maybe something can be arranged.
cd330 is offline   Reply With Quote
Old 01-15-2011, 11:30 PM   #3262
PEZi720
My Ride: PPIHC Racecars
well lemme know what happens... respond here... PM... whatev
PEZi720 is offline   Reply With Quote
Old 01-16-2011, 01:52 AM   #3263
Richaraiza
My Ride: TS2+ 330ci, 135i
Send a message via AIM to Richaraiza Send a message via Yahoo to Richaraiza
Definitely scr for subframe to kit. And yes labor is the killer. Iirc they charged me like 6 more hours because it just took longer than expected.
-Richard Araiza - EVO 3 SSK - D-FORCES - TC KLINES - LINEA CORSA Z2'S - ORION V2'S - ARGUAY LIP(R.I.P.) -
- ESS TS2+ - SS HEADERS - JB FLYWHEEL/CLUTCH - CF TRUNK - O.Z. ALLEGGERITA'S - CUSTOM EXHAUST - 3.23 LSD DIFFS ONLINE-
And much more...
Richaraiza is offline   Reply With Quote
Old 01-16-2011, 01:55 AM   #3264
Richaraiza
Originally Posted by evilstar View Post
wtf does trebdesumanu mean?
It's unamusedbert backwards. It's a denver thing that we started.
And much more...
Old 01-16-2011, 02:29 AM   #3265
PEZi720
the first rule of fyre crew........
ah fack it...
Old 01-17-2011, 01:55 AM   #3266
RonnieRenaldi
The OG
My Ride: Ferrari "RR430"
Just did a night shot experiment
RonnieRenaldi is offline   Reply With Quote
Old 01-17-2011, 10:22 AM   #3267
Brandond11
My Ride: 2002 M3
Send a message via AIM to Brandond11 Send a message via Yahoo to Brandond11
ah fack it...
And the second rule of fyre crew...
I like the pic Ronnie, the dark car really draws your attention to it.
Brandond11 is offline   Reply With Quote
Old 01-17-2011, 03:33 PM   #3268
Brandond11
My Ride: 2002 M3
Garrett I forgot to ask, are you just doing the rear subframe or did you go with the entire turner reinforcement kit? (The front upper reinforcement plates, the RSM plates, RLCA plates, etc?)
Old 01-17-2011, 04:17 PM   #3269
delirium45
My Ride: 2004 M3
just TMS subframe kit.
i've never had any problems with the front uppers, and my RSM's are significantly bolstered with the plates added from the cage.
is the RLCA plate just something to reinforce the RTAB pocket ?
_ Garrett
2011 Rocky Mountain Region GTS4 champion & "Rookie of the Year"
2012 Rocky Mountain Region GTS3 champion
Thanks Sponsors: SCR Performance & Built-by-Bones
delirium45 is offline   Reply With Quote
Old 01-18-2011, 09:53 AM   #3270
Brandond11
My Ride: 2002 M3
I guess... It looks like it just goes under the rear spring perch. The ad says that E46 are notorious for that failing but I think you'd have to have some serious stress on that arm before the perch went through, but maybe the higher spring rates give that stress? Anyone heard of this?
edit: The turner kit doesn't come with these, I was getting them confused with another kit I saw that came as a "reinforcement package" grouping some other high stress parts with the TMS kit.
Old 01-18-2011, 09:57 AM   #3271
delirium45
My Ride: 2004 M3
yes, i've heard/ seen this, typically if the spring load is not spread, most common with adjustable spring perches that mount to a small area on the bottom. i don't have any issues right now, and when i upgrade my suspension (probably next year) i'll likely go with full coilovers back there too, i do have pingpong paddle reinforcements that i can put in if decide to up the spring rate before going full coilover.
_ Garrett
Old 01-19-2011, 12:35 AM   #3272
Cazz
My Ride: 2005 BMW M3
LIES.
OK, maybe there are only 1 or 2 Denverites on here, be we are fierce.
Cazz is offline   Reply With Quote
Old 01-20-2011, 01:14 PM   #3273
Brandond11
My Ride: 2002 M3
My GC coilovers came with those ping pong paddles for reinforcement too.
Old 01-20-2011, 02:53 PM   #3274
delirium45
My Ride: 2004 M3
exactly, mine are left over from my GC c/o from my 330
_ Garrett
Old 01-20-2011, 08:58 PM   #3275
EK
My Ride: 02 M3
WAT!?!?!?
I live in Denver
(although I believe if I walk across the street I'm technically in a Greenwood Village)
EK is offline   Reply With Quote
Old 01-20-2011, 10:49 PM   #3276
PEZi720
i'm getting way too ridiculous with the AX build... although... i believe gramps will prolly approve
teaser
Old 01-20-2011, 11:15 PM   #3277
delirium45
My Ride: 2004 M3
ltw ftw !
btw; did you intend to have the rear of the hood not line up with the fender ?
_ Garrett
Old 01-20-2011, 11:56 PM   #3278
PEZi720
yes... its called something but i don't know the name... its a cooling mod based off of how nascar air induction works
that area is a dead spot, so as the air moves over the car it pulls it down through the rear of the hood for lower underhood temps.... it will help me more than any fuel injected car because of the location of the carb
THE PROBLEM is that the hood is so floppy now with the supports removed that only the sides sit higher... i need to make another bump stop of sorts for the center off of the firewall to hold it up all the way across
Old 01-21-2011, 08:24 AM   #3279
Richaraiza
Lol, when are you going to fix the fender.
Where the frock is azzy. I am unamusedberting.
I also wanted to ask if any of you all are going to the 24 hours of le mans? If you are by some freak chance hit me up.
Rumor is that 4ngiefest might be at road Atlanta anyone going to that also? maybe? I know you all are coming to visit, right? You have to. I miss Denver sooooooo much.
And much more...
Old 01-21-2011, 10:52 AM   #3280
Brandond11
My Ride: 2002 M3
Rich I'm looking into cars right now for the LeMons race... If I can find a car that will at least get us out there and reliable then I'll post up looking for drivers. I figured Anthony, Gramps, Azzy (BUT it seems he has gone MIA...), myself, and maybe you it sounds? I'm just not sure if we can get the car built soon enough for this years race...
I'm thinking about going to 4ngiefest this year since we didn't go last year! I need roadmates though!!! I guess i could meet up with the St. Louis guys and maybe the KC guys.
edit: I was contacted by Mellow Mushroom and they'd like to get us in there for maybe a monthly meet, or something of the sort. They would do beer and pizza specials. The owner of it is a fellow BMW owner it seems, I wonder if he's on the forums... Anyway I'll continue to work with them and then post up the info so we can get something going on. Also I am working with Invesco and CraigPara to get a Colorado Motorsports day that will have AX, shows, live bands, marketplace, etc. I'll keep you guys updated with that as I'd like to see us all roll in together if thats at all possible.
bmw exberts, colorado, denver, fifi, gaga ooh-la-la, kitty puuuuury, mile hi, more than you can afford, rolf, saint louis!, spee, steven was huuuurrr, steven's a girl eepsspee, toolberts, trebdesumanu, tuuuuuuuuuuuurbo awd?, vtec power
Rate This Thread
