Old 04-21-2010, 06:07 PM   #1
sleeker
My Ride: '01 325CI
mystery cooloant
'01 325 147000 miles. have new w/p & xpansion tank + trans thermostat
i'm getting coolant on the air filter box, little on the power steering resvr.
a bit on the fan blades, & a bit on top of the xpansion tank. any ideas ?
top hose is new too
sleeker is offline   Reply With Quote
Old 04-23-2010, 07:44 PM   #2
325myAZ
My Ride: 2001 325i
Hmmm, when I had that problem it was because my expansion tank was shot, but yours is new.
Did you check to make sure the upper bleed screw is properly secured? It should have an o-ring on it too...
You're sure that the hose is properly secured as well?
Cap on the expansion tank is tight?
325myAZ is offline   Reply With Quote
Old 04-23-2010, 08:17 PM   #3
sleeker
My Ride: '01 325CI
will be sure to take a look. top hose is new though
