E46 HK Sub Amp Wiring Diagram - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 67 votes, 5.00 average. Display Modes
Old 04-22-2010, 08:40 PM   #1
djtrini
My Ride: 04 M3 & 05 330i ZHP
Hey guys.
IM trying to install a LOC in my 05 E46 330i Sedan has the HK system.
I want to tap off the Sub amp on the rear deck, I have used the full range method from BSW in my M3, and I found that I couldn't turn the volume up very loud without losing output with my subwoofer.
anyone have any ideas?
djtrini is offline   Reply With Quote
Old 04-23-2010, 04:41 AM   #2
Arty
My Ride: 1999 328i
The wiring diargam can be found here. You will ned Java and the Adobe SVG viewer.
Arty is offline   Reply With Quote
Old 04-24-2010, 01:04 AM   #3
okeydokey
My Ride: 2000 328ci TopazBlau
coming from the amp the rear deck speakers are the larger wires
black plug -
Pin # 25 / Woofer Rear Right +Blue
Pin # 24 / Woofer Rear Right -Brown
gray plug -
Pin # 2 / Woofer Rear Left +Yellow
Pin # 1 / Woofer Rear Left -Brown
http://forum.e46fanatics.com/showthread.php?t=245914
///BMW 328CI 5 speed
okeydokey is offline   Reply With Quote
Old 04-24-2010, 12:50 PM   #4
ca1242
My Ride: 2003 330i
Do not tap on the oem sub amp or rear deck speakers. If you want a clean signal, tap into the head unit outputs, which can be located going into the oem (main) amp on the left side of the trunk behind the liner. 4 twisted pairs with orange/brown grounds are coming from the front the blue/black and yellow/black are the rear channels.
Make sure the loc can handle a balanced-differential. Some amps can also handle a balanced-differential signal directly and do not need a loc. You probably didn't have good results because the adapter wasn't appropriate.
Old 06-21-2010, 09:11 AM   #5
Blacksage
My Ride: E46 M3
black plug -
gray plug -
Can anyone clear this up? The last two people said different things. I tapped these wires from the factory harness leading to the oem amp and connected to a LOC and ran RCA's to my old alpine amp. The amp powers up but there is no sound from the sub...
EDIT! Search is my friend, looks like these wires are wrong
http://forum.e46fanatics.com/showthr...ighlight=sven4
Blacksage is offline   Reply With Quote
Old 06-23-2010, 08:51 AM   #6
ca1242
My Ride: 2003 330i
Actually both would work, but tapping into the rear speakers (wire colors above) is not the cleanest way to do it.
Old 06-23-2010, 01:27 PM   #7
okeydokey
Originally Posted by Blacksage View Post
... looks like these wires are wrong
In your first post said you wanted to tap the rear deck speakers. That was the info I gave you. I also linked you to a post that had a detailed pin-out of the amp plug.
Old 03-18-2012, 03:09 PM   #8
Killacoupe
My Ride: E46 coupe
Hi people i know this thread is old but i need some help.
I have a 2000 318ci with a standard bmw radio, i recently bought an hk woofer and need detailed instructions on how to connect it to my radio. Im not an electonics guy so it will have to be "clear".
Thanking who ever can help in advance
Killacoupe is offline   Reply With Quote
Old 10-19-2012, 09:43 AM   #9
328isawesome
My Ride: Batmobile
+1 on the previous post, I'm looking to do something very similar, also Killacoupe, if you found out how to do it please let me know.
Daily: Honda Fit EX 6-MT
PITA: 330i e90 6-MT
Past: 328i e36, 323i e46 Both Automatics
328isawesome is offline   Reply With Quote
Old 10-23-2012, 05:04 PM   #10
Beamer Creamer
My Ride: 2005 bmw m3
I tapped into my passenger vanity light circuit for signal wire for amp. Everything else could return to absolute stock.Couldnt think of a better circuit that wouldnt matter to me if fuse blew. Know of any better not in engine comp? I removed the 2 "subs" haha in pod and ran speaker signal wires from speaker connectors to high output converter( transforming speaker signal to rca outputs) then to amp. Had a rockford 800a2 powering a 12" boston g5 at 1 ohm and of course cooked amp by turning up converter controls too much and not stopping soon enough when could smell the overheating. Mmmm.
Beamer Creamer is offline   Reply With Quote
Old 10-26-2012, 01:10 AM   #11
joshism
My Ride: 04 330CI Convertible
Your amp has speaker level inputs, which are superior to RCA. You could have avoided both frying your amp and purchasing that LOC. I also bought a LOC, and discovered that my JL JX500/1d amp also has Hi-level/speaker level inputs. Good thing I sold it on ebay for the same price I bought it for.
joshism is offline   Reply With Quote
Old 10-26-2012, 08:45 AM   #12
Beamer Creamer
Ya i saw the input on side of amp but for some reason didnt want to look into buying the connector i prob threw out. I used a $35 LOC b4 and it wailed subs for years. Should have got connector. The LC2 i bought for $100 was too tricky for me to set both amp and LOC i guess. Whats best way to hold sub box solid! And look good? I used 1 ratchet strap over top of box to hooks but moved way too much driving hard
Old 08-12-2014, 08:39 PM   #13
/Stifmeister
My Ride: 330ci M-Sport
Hey guys I was wondering where I could find the stock amp wire cause I'm trying to hook up my batman kardon sub I just bought with a amp built onto it
/Stifmeister is offline   Reply With Quote
Old 08-13-2014, 08:52 AM   #14
ca1242
My Ride: 2003 330i
Left side of the trunk on non-convertibles.
