#21 | |
#22 | |
Stay stock my friends!
If there's a connector hanging free, and it fits into the alt that has an empty connector, you know that's the one. Every connector it seems has a slightly different config...not all of course, but if it plugs in and there isn't any slack in the line, they were meant to be together. Anyway, since there's only the alternator and a connector, and I know the alt has a replaceable voltage regulator, I'm pretty sure that's what the connector is for. Might it have failed...you'll see when you plug it in whether it's firm or not...might've had someone nick it in prior repairs somehow...might never have known. Doug
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#23 |
Sorry, backup a little. I'd assumed the extra wire was one with a connector at the end, but now I'm wondering if you mean just a single wire hanging around?
If this is a small wire and there's an empty hole in the connector already plugged into the back of the alt...then get new connector and hook new wires into it...think that'd be best...you can't really just stick a wire into a connector hoping it'll stick...it'd be very squirrley! If the wire is 1/4" thick or so hanging loose, that's the cable to battery...and it should be bolted under the rectangular black rubber cover on back of alt. Sorry if this confuses you...does me too! Doug
#24 |
its not a wire that is bolted on, its just a wire that is connected to a plastic connection piece at the rear of the alternator on the black plastic portion of the unit
EDIT here lemme find a pic of it, somethign about this wireis just bothering me Last edited by joneperry; 04-29-2010 at 07:15 PM. |
#25 |
![]() here it is see that connection thingy with two prongs tahts the one im referring to (under circle #1), it has nothing plugged into it but there is a wire nearby that looks like it will fit but it is hanging loosely, but im just afraid to plugg it in because it might screw something up in the electrical system (ex. im talking about it was faulty, so instead of replacing it, the dealer just removed the connection prior to my purchase and hoped that i wouldnt notice, but if i did plug it in, it would do no good to the electrical system *just an example, speaking hypothetically**) and the connection does appear to be part of the voltage regulator, but the wire that is suppose to connect to it.... what is it for? and its suppose to be connected right? Last edited by joneperry; 04-29-2010 at 08:50 PM. |
| Tags |
| alternator, battery, charging, electrical, volts |
