Old 04-23-2010, 06:16 PM   #1
vinnybones
My Ride: E46 330i & E46 M3
Decent oil leak
So for the past 2 days iv been noticing oil drips so last night I put a piece of cardboard under my car and this morning it was covered in oil. It is towards te front of the engine, and towards the drivers side. I called a friend and he said it sounds like my "main seal" . Is this a DIY for somebody with minimul skills or should I go to a Indy shop? Also how much ad I looking. Est. Price of course
thanks!
vinnybones is offline   Reply With Quote
Old 04-23-2010, 07:26 PM   #2
///Orient3
My Ride: can't be defined
thanks!
Actually, if it was your front main seal it would be more in the center. Because you describe it as more on the driver's side, my bet would be oil filter housing.
[url=http://photos.e46fanatics.com/showphoto.php/photo/90077]
///Orient3 is offline   Reply With Quote
Old 04-23-2010, 07:28 PM   #3
ChasCan
My Ride: 2001 330xi
Originally Posted by ///orient3 View Post
actually, if it was your front main seal it would be more in the center. Because you describe it as more on the driver's side, my bet would be oil filter housing.
+1
ChasCan is offline   Reply With Quote
Old 04-24-2010, 04:50 AM   #4
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Some people call the crank seal the "front main seal". But like Orient said, could be your oil filter housing. Check it out. Pretty common culprit.
Old 04-24-2010, 08:24 AM   #5
packrat555
My Ride: 2001 325i
oil filter housing gasket a 5 dollar part the dealer with charge $500+ to repair. It's easy but takes some time because of all the stuff in the way. There are good DIY here.
packrat555 is offline   Reply With Quote
Old 04-24-2010, 09:53 AM   #6
paraklas
My Ride: ESS TS2 320ci
Are you sure it's not ATF (Power steering fluid) ?
Old 04-24-2010, 09:56 AM   #7
BMWespresso
My Ride: 2005 325CI
large O ring for the filter housing cover, the one that comes with the filter, check were the plastic top meets the aluminum housing
BMWespresso is offline   Reply With Quote
Old 04-24-2010, 12:53 PM   #8
vinnybones
Well I replaced it and it still is happenin. I'm dropping it off on Tuesday and in gonna tell him the places to check (where you guys said) to help him out finding it and maybe save me some labor time. Thanks guys. My power steering is blown, the resivior is empty duevto it being a almost 2 months without it.
