BBS CH losing air - use sealant? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 04-25-2010, 05:05 PM   #1
KtecR
My Ride: ZHP, S2K, 4Runner
Send a message via AIM to KtecR
Two of my 19" BBS CH wheels (front right and back left) consistently lose air. The front right has been losing around 10psi per 3-4 weeks for the past 6 months and the back rear loses more like 20psi per 2 weeks for the past 2 months. It is becoming very aggravating to have to put air in every couple of weeks so I've now come to the conclusion that this has to be fixed for cheap or these wheels gotta go.
I've done the search and so far the differential is: Rim crack/bent, valve stem rubber leak, tire not seated, nail/penetration. The front right has a slight bend so that may the issue but its not a huge dent and the back seems straight. There are no nails in either tire so can't be that either. These tires have been on the wheels for about 2 years so I doubt it is the seating. I am down to valve stem rubber or the bends. Do you all think I can just use the can tire sealant to fix this problem? Are there any problems with trying this out?
2008 S2000: Chicane Silver/Red; 6 spd
2007 KLR 650
2004 330i ZHP: AW/Gray Leather; 6spd
1996 4Runner SR5: White/Tan
1980 CB400T
Sold:
2000 328Ci: TiAg/Black Leather; 5spd
2004 M3: TiAg/Black Leather; SMG
1995 318i: Arctic Gray/Gray Leather; 5spd
1986 325es: Red/Black Cloth; 5spd
KtecR is offline   Reply With Quote
Old 04-25-2010, 05:11 PM   #2
ChasCan
My Ride: 2001 330xi
Take some Fantastic or 409 cleaner & spray the wheel beads & valve stem. These 2 items will bubble real easy & now you will know where your leak is. If no bubbling at either of these 2 areas, then you might have a puncture in the tread area where the object of the puncture never stayed in the tire. Now you have to spray down the whole tire. Chas
PS: Try to avoid using tire sealant. It is really for emergencies only, as it will mess with your tire balance.
ChasCan is offline   Reply With Quote
Old 04-25-2010, 06:36 PM   #3
carcus
My Ride: 2006 BMW M5
Fix a Flat is a nightmare for tire places. Do not use it. Take the car to a Tire Rack, have them remove the rims. Most people coat it with soap and look for cracks where the bubbles come out. Could be something you do not know about. I once had a rim that had a pin prick in it...caused a leak. Just have the best local tire shop dunk them and check for leaks. I would not imagine if these are new rims, the alloy has a leak....but can happen. Hope this helps. Should not cost you that much. Hopefully it is the tire and not the rim.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 04-26-2010, 08:23 AM   #4
KtecR
Thats exactly what I am hoping - the tire not the rim. I'll find a place as soon as I get a chance. Luckily the weather is good and the motorcycles are running good right now (knock on wood)!
2007 KLR 650
1980 CB400T
Sold:
Old 04-26-2010, 11:53 AM   #5
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
There are cases that rims can have a pin hole leak or a slight bend to cause leaks. The more common cause would be from the valve stem rubber, hairline crack, or bent wheel. Water or dunk test would be the easiest to determine this.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-30-2010, 01:27 PM   #6
KtecR
Thanks for all the help guys. It turned out the wheel that could hold the air for the least amount of time (rear left) just wasnt sealed right. The guy fixed it right away in less than 5 mins. The other (front right) that held air for about 3 weeks has a crack in it :-/. Its ok though, doesn't look bad and it might be able to be fixed. Until then I am running Type 44s
2007 KLR 650
1980 CB400T
Sold:
