Old 04-26-2010, 05:09 PM   #1
Nicad
My Ride: e36 M3/4 e46 325it
Spark Plugs....How much??
I would bet it costs about $400 locally from a dealer to have the spark plugs changed once you factor in taxes and miscellaneous rag and solvent fees. I was shocked when they said $209 just for the Plugs from the local dealer.
I Bought them for $96 (same model NGK's) from a local supplier. I think there must be some counterfeit ones floating about.
Nicad is offline   Reply With Quote
Old 04-26-2010, 05:16 PM   #2
2004bmw330ci
My Ride: 02 330ci 3pedals!
I paid about $15.00 each. My buddy got his for as low as $8.00...So it varys...
As for paying to get it done don't bother! It takes literally like 30mins to do!
2004bmw330ci is offline   Reply With Quote
Old 04-26-2010, 06:19 PM   #3
TLM
My Ride: 2001 325i Touring
That wouldn't surprise me to see a $400+ bill for a spark plug change at a dealer.
It's a pretty easy job to do on your own though. $8.50 a plug at autohausaz.com and 30 mins of your time and you will save $340 bucks.
I searched around for info on plug change frequency and it seems pretty consistent most guys/gals here change plugs every 50-60K. That's what I'm doing as well and so far so good. Plugs had a bit of brown chalky stuff on them, but the insulator and electrode were still in decent shape.
If your car has over 100K might think about oxygen sensors too. Again, probably get a whopping big number if the dealer did the work, but you will again save a bundle by doing it yourself. It's also an easy 30 mins job (as long as you don't drop the socket down into the motor, doh!
TLM is offline   Reply With Quote
Old 04-26-2010, 06:41 PM   #4
Megalocnus
My Ride: 05 330i ZHP/MT
NGK pack of six- $42.
http://www.bimmerzone.com/parts-spec...park-plugs.htm
I guess you can find them a bit chepaer than this elsewhere...
Megalocnus is offline   Reply With Quote
Old 04-26-2010, 08:08 PM   #5
E46330iguy
My Ride: Supercharged 330i
Spark plugs .com
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 04-26-2010, 08:16 PM   #6
bAby norAA
My Ride: 01 BMW 330i
counterfeit spark plugs? lol
you paid way to much for spark plugs. next time shop around a bit, and you'll find much better prices.
| VF Supercharged Stage 1.5| Southbend Stage 2 Clutch | ZHP Cams | Technik Headers |
bAby norAA is offline   Reply With Quote
Old 04-26-2010, 09:30 PM   #7
Nicad
Everything from Jet impeller blades to Viagra has a counterfeit component if there is money in it. In Canada, we don't have as many options for discounted parts unfortunately.
Old 04-26-2010, 09:32 PM   #8
Nicad
Nice price, will remember that. I just wanted some while I had the car apart. That 6th coil sure gave me a hard time coming out. Will be quicker next time unless I forget how to do it.
Old 04-27-2010, 12:12 AM   #9
Rubenk
My Ride: M35A2
Im sorry guys, I cant help but laugh at you!
Total plugs cost about 12.50$ for me and its about 30 minutes worth of work.
Pay me 100$ and i'll do it for you parts included!!
Rubenk is offline   Reply With Quote
Old 04-27-2010, 01:19 AM   #10
Nicad
What model plug are you getting 6 for $!2.50 for?
Old 04-27-2010, 01:25 AM   #11
Rubenk
My Ride: M35A2
Ngk-V-Power-Copper 2.49 each.
Those 4 tip plugs are a gimmick. Electricity takes the path of least resistance, those quad tip shits are not working like they advertise.
Old 04-27-2010, 04:16 AM   #12
Megalocnus
The quad tip is not meant to produce four sparks simultaneously. The primary purpose of this design is to extend the life of the spark plug. When one prong wears or oxydises excessively, the next one will take over. If there is only one ground electrode, the spark is gone when it wears out. A center electrode made of platinum alloy is also more durable than a copper one.
I replaced my sparks with NGK OEM at 120K miles. The old ones had some wear of course, but were still good. I've read people here saying their cars run better after they replaced spark plugs, but there was no noticeable improvement when I replaced mine.
Therefore you are very likely not saving any money with these cheap spark plugs in a long run since you are going to replace them more frequently.
Anyway, I'm glad these copper ones work for you, but don't want them in my car if you offer me $100 and come to install them yourself.
Old 04-27-2010, 12:18 PM   #13
Rubenk
My Ride: M35A2
If your plugs are "wearing" away like you speak of you have big problems, what you speak of simply doesnt happen. The only thing the other prongs do is shield the one prong that is arcing, therefore reducing the combustion mixture's exposure to spark.
I'm sure you'll find the majority of racers run copper plugs at their track. I challenge you to find any evidence that they are better than the single tip plug of your choice.
Old 04-27-2010, 12:25 PM   #14
JJR4884
My Ride: BMW
dealer charges $26 per plug haha
i bought mine for like $7 each off of alloemparts.com or something like that
JJR4884 is offline   Reply With Quote
Old 04-27-2010, 02:25 PM   #15
nathancarter
My Ride: 02 330i
oops, no. Google "spark plug electrode wear" and enlighten yourself.
Here, I'll save you some clicks:
This spark plug shown below has served its useful life and should be replaced. Voltage required to fire the plug has approximately doubled and will continue to increase the longer the engine operates.
Even higher voltage requirements (as much as 100%) above normal may occur when the engine is accelerated quickly. Poor engine performance and a loss of fuel economy are traits of worn spark plugs.
Long, reliable service life = better. Most platinum-topped 4-prong plugs are rated for 100k (though I choose to replace mine at Inspection II or about 60k intervals).
What's the service life of your copper plug of choice?
And, comparing "what racers do" to the street cars being discussed in this thread... well, it's simply not relevant. Do you run 100+ octane "like the racers do" when you're driving to work or the liquor store? No? GTFO.
nathancarter is offline   Reply With Quote
Old 04-27-2010, 02:38 PM   #16
quacktoduck
My Ride: e39
i got my ngk 2667s for 5.25each got the oreillys buddy discount but im sure i can get more
best plugs evarrrrrrr
quacktoduck is offline   Reply With Quote
Old 04-27-2010, 02:47 PM   #17
trizzuth
My Ride: 228k, 16yr old B3AST
if I were you, I'd cross the freakin border since you are close and find an advance auto parts. Got mine there for $7 each, $42 total for the car.
trizzuth is offline   Reply With Quote
Old 04-27-2010, 03:27 PM   #18
Megalocnus
Of course spark firing wears the electrodes- of any plug design. Ever seen a used plug?
The copper single ground electrode sparks have their advantages though - the copper has higher electric and heat conductivity. The latter helps when preignition becomes an issue - at very high RPMs, boosted engines injecting a lot of fuel, etc. This is why they are of choice for racing. However, the race cars' spark plugs are replaced just as often as brakes and tires - sometimes on a daily basis. If they are kept running longer, the copper would quickly become of disadvantage.
The shielding effect of the non-arcing three prongs you are talking about should be negligible if anything - these prongs are not standing between the arc and the fuel mixture.
You will convince me the copper plugs are better for my stock engine if there is any credible evidence that they have ever improved performance, reduced emmisions, etc.
While no such evidence exists, I'll stick with the more durable and reliable OEM spark plugs, thank you very much.
Old 04-27-2010, 03:56 PM   #19
Stingray230sx
My Ride: 01' 330ci-96' FZJ80
9.39 each from my local napa (oem and in stock)...so 56.34 plus tax out the door
Stingray230sx is offline   Reply With Quote
Old 04-27-2010, 04:49 PM   #20
Kubica
My Ride: 2003 325xi
I can't help but laugh at you since you used the wrong plugs.
