Sponsored by The Tire Rack
Old 04-26-2010, 04:44 PM   #1
xixixi
Banned User
My Ride: 01 330x-xi
Off set...
Will a 55mm offset work on a e46 330i/330xi???? anyone???
Old 04-26-2010, 04:46 PM   #2
guest11072016
Account closed.
Front or Rear? What's the width of the wheel and with what tire?
guest11072016 is offline   Reply With Quote
Old 04-26-2010, 05:15 PM   #3
xixixi
Banned User
My Ride: 01 330x-xi
it's a square set up i was hoping to run a 235/XX/17 the offset is 55mm all the way around. (wheels are 5/100...ET 35MM) (getting 5x120 to 5x100 20mm adapters) anyone??? heh
Old 04-26-2010, 05:22 PM   #4
guest11072016
Account closed.
So I'm guessing the wheels are 8.5 inches wide based on your tire selection. If you are adding a 20mm adapter (essentially a spacer) you will actually be getting an offset of 15mm not 55mm. You are pushing the wheel outward, therefore lowering the offset. This is guaranteed NOT to fit your ride bro.
Old 04-26-2010, 05:25 PM   #5
RAFF112
My Ride: 325ci M3 cbr 600rr
Originally Posted by pat View Post
So I'm guessing the wheels are 8.5 inches wide based on your tire selection. If you are adding a 20mm adapter (essentially a spacer) you will actually be getting an offset of 15mm not 55m. You are pushing the wheel outward, therefore lowering the offset. This is guaranteed NOT to fit your ride bro.
I think his wheels are ET55 and he wants to add a 20mm spacer making it ET35. In any case you'll be fine.(not even flush yet)
VCSL Front 18/13 Spacers Full Borla V2 K&N drop-in w/custom tube LED Interior air horn BMW performance shift Knob Seibon Hood LED DRL Dynavin Depo corners RE rear camber arms and Vogtland Springs.
Originally Posted by hayabusa55 View Post
I used to think love exists. Turns out it's a manifestation of insecurities and boredom.
RAFF112 is offline   Reply With Quote
Old 04-26-2010, 05:29 PM   #6
guest11072016
Account closed.
Aaaahh Okay.. I couldn't tell by how the message was written but this would be correct. He can even add a little extra in the rear.
Old 04-26-2010, 05:31 PM   #7
xixixi
Banned User
My Ride: 01 330x-xi
again to be sure the wheel is 35 e/t 5x100 (fact) i am buying custom adapters that are 5x120 to 5x100mm, they are 20mm wide so assuming the adapters are 20mm and the ET on the wheel is 35 with a bolt pattern of 5x100 (if this matters) how is the fitment??? all info is welcome .....
Old 04-26-2010, 10:31 PM   #8
cheech320
My Ride: Is TiAg
if you are adding a 20mm spacer(adapter) your offset will effectively be 15 and will not work without some work. You may need to stretch a smaller tire across that wheel, roll/shave your fender and maybe have them pulled.
-Anthony
Photobucket
cheech320 is offline   Reply With Quote
Old 04-26-2010, 11:28 PM   #9
guest11072016
Account closed.
ohhh.. then my initial assumptions were correct. You'll end up with 55mm offset. No go brah
Old 04-27-2010, 02:23 AM   #10
xixixi
Banned User
My Ride: 01 330x-xi
so is it 15 or 55? lol
Old 04-27-2010, 06:06 AM   #11
xixixi
Banned User
My Ride: 01 330x-xi
can i get 1x100 drilled to make em 1x120???
Old 04-27-2010, 07:53 AM   #12
BartenderPlease
My Ride: '03 540i/6 M-Sport
dude
so is the wheel et55 or et35?
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 04-27-2010, 01:02 PM   #13
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Im a bit confused throughout the thread.
If the wheels are 5x100, you must run bolt adapters to a 5x120, that are approx. about 20mm thick. This will virtually lower the offset from a +55 like you initially said to a +35. If the wheel IS 8.5" wide, +35 offset on a 235 tire is perfectly fine all around.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-27-2010, 01:23 PM   #14
guest11072016
Account closed.
Originally Posted by BartenderPlease View Post
dude
+1 ... this needs to be clarified.
Old 04-27-2010, 02:38 PM   #15
xixixi
Banned User
My Ride: 01 330x-xi
i apologize i was a little drunk when i wrote this yesterday. The wheel is 35ET I will need to adapters that are basically a 20MM spacer. hope this cleared it up??? can i get these drilled to a 5x120 bolt pattern??
Old 04-27-2010, 02:40 PM   #16
Snik
Snik's Avatar
My Ride: IR M3 Vert.
-Charles@VMRWheels
this...
Do you ride a sportbike?
Old 04-27-2010, 03:16 PM   #17
dizz81
My Ride: Money pit...
/Thread highjack
Have a set of VMR V710's
18x8.5 35mm fronts
18.9.5 45mm rears
Would these work on an 05 330ci? Would I need to change anything, or use an adapter for anything? Since this is an "offset" thread
/end highjack
dizz81 is offline   Reply With Quote
Old 04-27-2010, 03:17 PM   #18
Snik
Snik's Avatar
Originally Posted by dizz81 View Post
/Thread highjack
18x8.5 35mm fronts
18.9.5 45mm rears
/end highjack
perfect fitment. might even be able to run 265s out back too.
Old 04-27-2010, 03:24 PM   #19
BMWespresso
My Ride: 2005 325CI
won't work 35et with 20mm spacer is a 15et, no good, have a drink
BMWespresso is offline   Reply With Quote
Old 04-27-2010, 05:20 PM   #20
xixixi
Banned User
My Ride: 01 330x-xi
i scrapped the idea they are oz superleggeras off my buddies gti. like 17lbs a rim but i realized i would have a hard time getting replacements and be in the same **** i'm in now. bent 2 rims the other day. i'm just gonna ride my trek and save up for something that fits right
