Old 04-27-2010, 03:43 PM   #1
S2000
My Ride: E86Z4M, E60M5, M3
Which is the lowest floor mount ?
VAC
http://store.nexternal.com/vacmotors...all-p1604.aspx
or
Macht Schnell
http://www.europeanautosource.com/pr...oducts_id=2420
Which provide lowest seating position and most centered seating position?
S2000 is offline   Reply With Quote
Old 04-27-2010, 03:44 PM   #2
Giftee
My Ride: 2004 ZHP
yea...those links don't work.
Giftee is offline   Reply With Quote
Old 04-27-2010, 05:00 PM   #3
FTWeisse
My Ride: has no hip-hop rimz
The MS are identical to the VAC ones - and I mean IDENTICAL. I should know, I've got VAC ones in my racecar. My bet is that MS took a set of VAC mounts and "reverse engineered" them, making their own pieces.
That said, they offer pretty low seating position. For the lowest possible setting make sure you mount the seat as low as it will go in the side mounts - additionally, and I only recommend this if nobody other than yourself is ever going to drive your car, you can mount the side mounts directly to the floor mounts (e.g. don't use sliders). Your seat will be fixed, but it'll remove another inch of height.
