Old 04-27-2010, 06:04 PM   #1
FALS BMW
My Ride: BLACK BMW 325I
I need help, just replaced Duralast 49-DL on 4/26...
Hey Guys,
My wife just called me to say all the lights are on the dash board (shows bulbs out sing):
*****I just replaced the Duralast 49-DL on 4/26 from Autozone ****
Do you think I might have a bad battery; (it has a 7 year warranty.)
She said the car runs ok, but she is scared it may stop on her.
Please help!!!!
FYI: I did connect the vent hose to the battery.
Nilam
FALS BMW is offline   Reply With Quote
Old 04-27-2010, 06:09 PM   #2
FALS BMW
Before I replaced the batter, on 4/25,
she was coming home from our friends house and she started hearing popping sound from the speakers, and the radio turned off half way, lights started flashing on the dashboard.
this was before I replaced the battery.
Nilam
Old 04-27-2010, 06:14 PM   #3
bishop1977
My Ride: 04 330i ZHP S/C
check your fuses
bishop1977 is offline   Reply With Quote
Old 04-27-2010, 06:22 PM   #4
Stanc3
Stanc3's Avatar
My Ride: 99' JB 328i
Sounds like the alternator. The battery has nothing do do with the power of the car while its driving, it is used only to start the vehicle. the alternator runs the car once started, if the cars electronics are fading out while driving chances are the alternator is not butting out the 2 volts(+/-) that it should be, and it is now going to the battery for additional power, draining and damaging the battery.
Take it back to autozone and have them do an alternator test, and a load test on the battery.
- Albert Einstein
- Chad
Old 04-27-2010, 06:33 PM   #5
Messe46
My Ride: 325xi ZSP - ONRLS
Send a message via AIM to Messe46
Originally Posted by stanc3 View Post
take it back to autozone and have them do an alternator test, and a load test on the battery.
+1
-Mike
Im sorry, but having an Aston Martin DB9 on the drive and not driving it is a bit like having Keira Knightley in your bed and sleeping on the couch. If youve got even half a scrotum its not going to happen.
-Jeremy Clarkson
Messe46 is offline   Reply With Quote
Old 04-27-2010, 06:43 PM   #6
FALS BMW
If I take it back to the Autozone, and tell them to do a alternator test.
What do i need to look for?
What should I ask the guy?
Any numbers that I need to look for, ir so what should it be.
FYI: I just talked to my wife and she said she got home safe, but there are still warning lights on teh battery.
Battery light on
Lights on for (bulbs)
Nilam
Old 04-27-2010, 06:47 PM   #7
FALS BMW
Any numbers that I need to look for, if so what should it be.
FYI: I just talked to my wife and she said she got home safe, but there are still warning lights on the DASH.
Battery light
Nilam
Old 04-27-2010, 07:11 PM   #8
FALS BMW
Any input would be appreciated. I'm thinking about taking the car to the AutoZone tomorrow and get some tests done.
Nilam
Old 04-27-2010, 07:38 PM   #9
carcus
My Ride: 2006 BMW M5
Do what they said.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 04-30-2010, 05:29 PM   #10
Stanc3
Stanc3's Avatar
Battery light
Nilam
Nilam
with the car off and their machine hooked up, a healthy battery will be putting out 12 to 13 volts, if not, the alternator could be damaging it.
with the machine hooked up and the car on, you should see about 2 volts above whatever number you got with the car off (about 14 to 15), any less and the alternator is not doing it job correctly, and the car is turning to the battery for extra power, which it shouldn't.
They can get a little more detailed on the alternator with the same machine to check its output a little more precise. Any employee should know how to do this, unless your autozones filled with retards!lol.
- Albert Einstein
- Chad
