Old 04-28-2010, 06:22 AM   #1
mystert
My Ride: 2003 330Ci
Oil Drain Door P/N
Im looking for the P/N for the Oil Drain Door, number 3 in the picture, doesnt show a P/N for my 330ci with a 9/2002 build date. Ive got the reinforcement plate but no trap door and RealOEM doesnt show a P/N for the door. Im guessing the past owner or dealer forgot to put it back on after changing the oil previously?
MysterT Huntington Beach, CA
mystert is offline   Reply With Quote
Old 04-28-2010, 07:17 AM   #2
330I6SPD
My Ride: 2005 330I 6Spd.
Yeah, at the first oil change the techs like to "forget" to install it. Most owners have no idea it's missing until they stert to do their own changes. I need to get one too.
330I6SPD is offline   Reply With Quote
Old 04-28-2010, 07:31 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Most later model BMW's do not have this drain door as a standard item.
I think the Xi package and Diesels have it. If you search either Xi or Diesel models you should find the part number. As I recall it is about $15.
Also if you search the site carefully you will see folks have posted the part number.
Edit: If RealOEM does not show the actual part number, but the item is pictured, it usually means your car did not have this part as standard equipment!
Old 04-28-2010, 08:17 AM   #4
mystert
My Ride: 2003 330Ci
I found one for the 2003 M3 thats only $0.56??? That sounds too cheap to be right!
P/N 51717893279
Old 04-28-2010, 08:20 AM   #5
paraklas
My Ride: ESS TS2 320ci
It was around $9 when I got mine. I thought that there was 1 type only, apparently there are 2 types, one small and one large door. Unfortunately I got the small plastic door which left 2" gap
Old 04-28-2010, 08:26 AM   #6
mystert
My Ride: 2003 330Ci
Anyone have a P/N??
Old 04-28-2010, 08:27 AM   #7
Starless
My Ride: 02' 325i
I got one from Tisher. My order history does not show the part # nor do I remember it now but it's in their catalog.
OEM Catalog
COVER 1 $4.66 $0.00 $4.66
Status: Sent
OEM Catalog
C-CLIP NUT 1 $1.06 $0.00 $1.06
Status: Sent
OEM Catalog
CIRCLIP 1 $0.21 $0.00 $0.21
Status: Sent
Starless is offline   Reply With Quote
Old 04-28-2010, 08:52 AM   #8
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
P/N 51717893279
that part number would be correct if its the same cover for an m3.
when i type it in ETK it shows that fits all m3's. i've never been able to find that part in the catalog for any other e46
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 04-28-2010, 09:09 AM   #9
mystert
My Ride: 2003 330Ci
I just ordered the $.56 for the M3, well see when it gets here I guess!
If you anyone finds the P/N for the $4.66 one , please post it. Thanks
Old 04-28-2010, 09:30 AM   #10
Starless
My Ride: 02' 325i
I have the part number on my other computer, I'll let you know later when I get home. But I did find it on this site when I was looking for it, in one of the threads, so you can search and you'll find it. And you do need that little circlip with a little white washer and a screw too.
Old 04-28-2010, 09:48 AM   #11
BreakfastBurrito
My Ride: ///GT3 RSR
just checked real oem for my car, that part is not even shown... and it's not on my car
BreakfastBurrito is offline   Reply With Quote
Old 04-28-2010, 09:56 AM   #12
sammk
My Ride: Bone-stock E92
This is what you need (assuming that facelift sedans and coupes use the same part).
51 61 7 199 687 Cover $5.95
07 14 6 981 767 C-Clip Nut $1.95
Picture can be seen here - http://photos.linquist.net/gallery/6...20602806_BYqcN
If anyone needs the M3 part (which is circular), I have one I can donate.
sammk is offline   Reply With Quote
Old 04-28-2010, 09:56 AM   #13
shanneba
My Ride: 2003 330Ci
My 2003 330Ci build date 02/2003, originally had a cover, it didn't after a dealer oil change.
I had the parts department order one, part number - 51718197932 - the diagram shows up to 02/2001 so it didn't fit my car, it is too small.
It measures 6 4/3" wide by 5 1/2" long.
http://www.realoem.com/bmw/showparts...1&fg=70&hl=156
I would like to know the size of the M3 version to see if it would fit my car.
Old 04-28-2010, 10:16 AM   #14
Kubica
My Ride: 2003 325xi
Nah, xi's have to take both covers off to change the oil.
