Old 04-28-2010, 01:52 PM   #1
-matt
My Ride: 328 ci
rear subframe removal tool?
sorry if this is in the wrong section. and i have searched.
now i need to replace all 7 bushes on the rear subframe of my E46 328CI.
to make things easyer i have got a secondhand subframe, which ive removed the old bushes out of (easy bit).
now im having problems of thinking of how to get the new ones in fully.
ive had a plan, and seen something simular on here somewhere.
large rod, a nut on the end, large washer then the bush, then something on the other end (piece of metal with hole in) that will grip hold of the subframe, then washer and nut on the end. then tighten the nuts.
now im pretty sure this would work to get the bush most of the way in, but the bush pokes out of the end 1/4 inch, so would need something else to get it fully in.
so any ideas? would i be able to hammer it the rest in?
or any better ways to make the tool?
cheers,
matt
-matt is offline   Reply With Quote
Old 04-28-2010, 01:59 PM   #2
paraklas
My Ride: ESS TS2 320ci
since you have a spare subframe, just take it to a shop with a hydraulic press. When we did mine, with the hydraulic press it was a 10 minute job.
Old 04-28-2010, 02:03 PM   #3
SNORCE
My Ride: 2005 ///M3
i have to do this to...i went to a shop and he want 500 for labor and 250 for all 7 bushings...but is it easy to do it myself??
SNORCE is offline   Reply With Quote
Old 04-28-2010, 02:32 PM   #4
-matt
My Ride: 328 ci
i have tried a few places but they have either wanted stupid money (10 per bush) or said there press is not suitable.
how much pressure is needed? would a 1 ton arbor press do the job? like this one: http://cgi.ebay.co.uk/Heavy-duty-rac...item563b8e3f1f
but i would need to find something to put under the subframe so that the bush can come through.
Old 04-28-2010, 03:03 PM   #5
SNORCE
My Ride: 2005 ///M3
is this all i need ??? subframe and diff bushing???
http://www.ecstuning.com/BMW-E46-325...ngs/ES1897129/
