///M3 Forum
Old 12-10-2009, 12:57 PM   #1
badhbtz
My Ride: E46 M3
Oil Temp Gauge Acting Up.. Picture attached. Advice anyone?
The Arrow points to the item I am referencing.. This Oil temp gauge sometimes shows the temp accurately.. and sometimes it looks like this in the picture.. Dead.. Like its not active. Im sure its the sensor but there are a few to contend with. Does anyone know which sensor is linked to this puppy?
Thanks!!!
01' M3 - 6puck ceramic/LW Fly
badhbtz is offline   Reply With Quote
Old 12-10-2009, 02:58 PM   #2
badhbtz
My Ride: E46 M3
Comeon Fanatics!! 20 People have viewed and nobody cares to help?
Help a brother out now..
Old 12-10-2009, 03:02 PM   #3
dino71
My Ride: 2003 BMW 330i
I dont end a M3 but I think your temperature sending unit is probably broken. Its usually threaded into the oil pan..maybe? I know there are sending units for oil pressure but I guess they have them for temperature too. I would call the dealership and ask them is a sending unit exists for your car. I hope this helped.
dino71 is offline   Reply With Quote
Old 12-10-2009, 03:07 PM   #4
Custom3
My Ride: HellRot 330CI
oil temp sensor?
lucky m3 owners get a oil temp guage there....we get a f*cking useless mpg guage
Old 12-10-2009, 07:28 PM   #5
api
My Ride: 03 M3 6-spd
My first question is, you list that your location is Michigan but you have a Euro Tach. This does not seem standard on a US car. Why is this?
If you have a swap I would check to see if you might have a loose connection in the back of the cluster. If that is good I would check your sensor to see if that has gone bad.
MODS: 03 M3, 6MT, PSS9, AFE Intake, El Diablo Exhaust, Turner Motorsports Rear Adjustable Camber Arms, PowerFlex bushings, 18'x9' square setup & one driver that grins ear to ear everytime he is driving it
api is offline   Reply With Quote
Old 12-10-2009, 08:10 PM   #6
johnm
My Ride: TiAg M3
The oil temp sensor is on the RHS of the oil filter. The control module is under the glove box- it's common with the oat display. Was it cold out when you took the picture or is the oat acting up too? If so you may have a problem with the module. F23 and F31 are involved. If it's just oil temp it's most likely the sensor or wiring. Second choice'd be a problem within the cluster.
Cheers
JM
johnm is offline   Reply With Quote
Old 12-10-2009, 10:25 PM   #7
mredwin25
My Ride: E46 M3 E90 325i
the oil temp sensor is located on the oil pan, not on the filter housing, it is very common for it to fail on the M3. Look at the pic it is item #12, PM me I have a spare one in my spare parts box.
E46 M3 Imola/Imola AA ASA Supercharger Prototype Kit, Headers, Intake, RE rasp pipe, ZCP OEM wheels, Vogtland Springs, Konis, TMS sways.
mredwin25 is offline   Reply With Quote
Old 12-11-2009, 01:08 AM   #8
azndrunk74
My Ride: LSB vert
yup oil temp sensor, i have the same issue. it's especially annoying because performance and MPG drops too.
LSB|Cinnamon|Hardtop|VCSL GTS3 Diffuser|VCSL Bumper|VCSL Single Sided CF Bootlid|AA Gen 3|UUC SSK|VOLK Mercury Silver TE37|Bilstein PSS9|GC RSM|Euro Cats|Headers|Avic Z3 NAV|
azndrunk74 is offline   Reply With Quote
Old 12-11-2009, 07:43 AM   #9
badhbtz
My Ride: E46 M3
I do live in Michigan.. This is a Euro Spec M3 very rare.. It came in thru Canada. Im just looking for some help on how to remedy the sensor
Old 12-11-2009, 07:45 AM   #10
badhbtz
My Ride: E46 M3
Attachment 341122
Sent you a PM!! thanks guys!
Old 12-11-2009, 07:49 AM   #11
badhbtz
My Ride: E46 M3
Cheers
JM
Thanks for the info! i will check all these items!
Old 12-11-2009, 08:37 AM   #12
mredwin25
pm's replied
Old 12-12-2009, 07:37 AM   #13
johnm
My Ride: TiAg M3
Attachment 341122
You sure that's not the level sensor (thermal level sensor to be precise)? ETM shows the level sensor in the sump and the temp sensor in the filter block.
Cheers
JM
Old 05-06-2010, 02:23 PM   #14
///M3PO
My Ride: 2004 M3
Hey guys,
Relatively new M3 owner here, but I am encountering the same problem. I searced the forum for a little more info but this was about the most useful thread I could find.
I ordered a new oil leveling sensor from Autohaus and just had the oil changed and new sensor installed earlier today and the guage still does not inidicate the temp(plus i get the yellow light staying on ~10 seconds after ignition) after a spirited drive back from the shop. I'm gonna go ahead and assue the shop tech knew what he was doing and installed it properly. Any idea what my next step could be?
///M3PO is offline   Reply With Quote
Old 06-08-2010, 03:36 AM   #15
roysefus1
My Ride: Mercedes C-Class AMG
Im having the same problem so maybe we could work together.
roysefus1 is offline   Reply With Quote
Old 06-08-2010, 08:26 AM   #16
M Shark
My Ride: '04 M3
I might have this problem in the future so I'm bookmarking this page. LOL!
_____________________________________________
M Shark is offline   Reply With Quote
Old 06-08-2010, 08:43 AM   #17
sick.boy1986
My Ride: ///M3
Try searching m3forum.net, if you don't find anything, post there.
MALA MALIS FACIMUS.
sick.boy1986 is offline   Reply With Quote
Old 06-08-2010, 04:47 PM   #18
wtm1417
My Ride: LSB E46 M3
Yeah as mentioned above this is a common issue for e46 m3's. I had to change mine several months ago and it wasn't too hard. Next time you need to change your oil just drop the plastic skid plate in front, and then the metal skid plate behind it. Then you will see the oil leveling sensor held in by 1 torx bolt i think. Just swap it out after you drain the oil. Took less the 45 min. I think if you search oil leveling sensor you will find more info.
wtm1417 is offline   Reply With Quote
Old 06-10-2010, 11:35 AM   #19
roysefus1
do the codes have to be cleared after installing the new oil temp sensor?
Old 06-10-2010, 09:06 PM   #20
azndrunk74
My Ride: LSB vert
^^^ nope
